WTB : Final Expansion 3
- majikeyric
Hello,
I'm looking for a Final expansion 3, where can I purchase it from ?
Many thanks.
Many thanks.
Re: WTB : Final Expansion 3
I got mine from Sinchai.de . Seems like it's back on bussiness.
http://www.sinchai.de/index.php?main_pa ... ucts_id=77
Regards
Regards
majikeyric wrote:Hello,
Many thanks.
- majikeyric
Many thanks !
I have just placed my order
It is not too difficult to assemble ? (I have already used a soldering iron).
![Very Happy :D](./images/smilies/icon_biggrin.gif)
![Cool 8)](./images/smilies/icon_cool.gif)
hmm, i just went there and it says out of stock.....
I soldered mine myself and it's an slow process but not difficult. SMD components come already soldered on mine.
Take a look at
http://www.sinchai.de/index.php?main_page=page&id=10
It's a detailed step by step visual guide of the soldering process.
Regards
Take a look at
Regards
majikeyric wrote:Many thanks !![]()
I have just placed my order![]()
- majikeyric
I'm progressing slowly soldering the "beast"
it is not that hard.
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Great!
I finished soldering a second FE a couple of days ago (for friend with no soldering skills).
I took pictures of the entire process on the way![Smile :)](./images/smilies/icon_smile.gif)
- majikeyric
I like hardware pictures
I have finished soldering my FE3, it works like a charm !![Very Happy :D](./images/smilies/icon_biggrin.gif)
I don't see any difference between the use of the 2 RESET buttons, both bring me the FE3 menu, is it normal ?
I have read that the yellow button keeps the memory configuration while the red do not but I can't confirm...
Try dropping to Basic (edit - why did I write Does?) with 16k expansion and wedge then reset.
One button should reset the Vic only, the other should go back to the menu from memory.
- majikeyric
Thanks Ian, it works after having chosen a RAM configutation with the RAM Manager (F1 key).
But why it doesn't work after hitting F7 in the main menu (BASIC Wedge) ???
Not sure. Will try mine later.
