Vic 20 Screen and Character designer
rhurst
Omega Star Commander
Occupation: Tech & Innovation
Re: Vic 20 Screen and Character designer
Post by rhurst »
Yes, other browser support helps, although works fine using Chrome (on Linux). Some suggestions:
It looks like it supports only decimal numbers (0-255), please allow an option for load/generate text as binary (%00000000-%11111111), decimal (0-255), or hexadecimal ($00-$FF) notations.
Generating and allowing for an optional tag per character (i.e., mychar00: - mycharFF:) can help.
Jeff-20 wrote:P.S. - make Popeye, please.
I got demand to make Berzerk, wow, Jeff says "please" to you... not certain how I feel about that? :?
Well, you're going to have to deliver now for the island king of misfit toys here. :twisted:
rhurst wrote:It looks like it supports only decimal numbers (0-255), please allow an option for load/generate text as binary (%00000000-%11111111), decimal (0-255), or hexadecimal ($00-$FF) notations.
It will import hex numbers in $nn format already but not export - I'll add your request to the list...
rhurst wrote:Well, you're going to have to deliver now for the island king of misfit toys here. :twisted:
..I'm waiting for SSS to support multicolor masking :wink:
beamrider wrote:
Ok, I've made some changes and uploaded a new version (0.3)
It now seems to work [apart from a few minor niggles] in Chrome, Firefox and Internet Explorer (11).
Please give it another try.
That's a lot better, I can now edit and change colours in the Character View. Something still seems up with the Screen View, Draw just doesn't do anything.
It works for me under latest Firefox.
Are you sure you have:
a) selected the Draw radio button
b) selected a non-blank character in the list and set the foreground colour to something visible?
Can you see anything if you change the "Screen view as:" ?
p.s. also make sure you have cleared out the browser cache..
rhurst
Post by rhurst »
Yes, clearing the cache helped me.
beamrider wrote:..I'm waiting for SSS to support multicolor masking :wink:
lol, your first mistake was using it in the first place. But I am thinking of doing a separate 8x16 bitmapped mode API.
rhurst wrote:Some suggestions:
A new version (0.31) is up with this functionality added:
as before, a hard cache reset is advised.
rhurst wrote:I am thinking of doing a separate 8x16 bitmapped mode API.
YES!!!!! :mrgreen:
Now upgraded to version v0.32
New features:
* 5 work screens available
* Table now has multiple selection (use shift or ctrl) and colour/mc can be set for many rows at once.
* Copy and paste table rows
* Optional RLE (run length encoding) mode for screen and colour data (honoured on import and export)
Char: >128 = single value representing an actual value 0-127 (subtract 128) when reading
Char: 127 = end of sequence indicator
Char: <127 = RLE length, following char = RLE value (0-255)
Other:
* Table apperance tidied up
* Import/Export split into two tabs..
As before a hard cache reset is advised...
Misfit
Post by Misfit »
Thanks,
Few minor requests:
- Could you add support for alternative mouse control. (same button could provide ON/OFF functionality)
- Now black border colour hides texts
Misfit wrote:Thanks,
Few minor requests:
I've uploaded v0.33:
- Black border issue fixed.
- added a toggle mode for the character view.
The toggle mode can be enabled in the settings tab (persisted). The default setting is off as I'm not sure I like it (especially when drawing as opposed to just clicking individual bits). For multicolor characters it cycles round the 4 available colours.
Misfit
Post by Misfit »
Few minor requests:
Reason why I requested this feature it is that I use trackpad and sometimes it's easier to use same button when you draw. But great job again.. thanks
I've uploaded a new version (0.34)
Additional features:-
* Holding down the Ctrl key whilst drawing on the screen designer constrains to horizontal or vertical plotting of characters
* Undo/Redo facility
As before please clear the browser cache.
Really enjoying this! It's hard to think of ways I would improve this. It's amazing. The most I could think of was a 16 by 16 mode. The 8 by 16 is great. I often like to make wide images too. Or maybe the ability of rotating a single character 90 degrees.
Sent from my phizzone
Jeff-20 wrote:Really enjoying this! It's hard to think of ways I would improve this. It's amazing. The most I could think of was a 16 by 16 mode. The 8 by 16 is great. I often like to make wide images too. Or maybe the ability of rotating a single character 90 degrees.
Thanks!
I've uploaded a new version (0.35) with +/- 90deg rotation (8x8 only).
Enjoy!
