Vic 20 Screen and Character designer
Re: Vic 20 Screen and Character designer
Just to add a couple of things to what John said..
First, as I mentioned before make sure you do a proper refresh Ctrl+F5. I tried and it works in Chrome and Firefox although IE currently has issues with the code. I'll get around to fixing that in due course.
Second if you don't want the MiniPaint character layout take the following steps to edit a bitmap of the required size (of course respecting a maximum of 256 unique characters)
1) In the main screen area select the required bitmap area (Select All button selects the entire screen).
2) Select the character in the table where you would like the bitmap to be allocated from.
2) Click "Layout Cols" (or Rows as prefered)
3) Click "Edit as Bitmap"
4) The bitmap window will open
5) Click "Select All" in the bitmap window.
6) Click "Clear" to "wipe" the character data for those characters.
7) Edit as required.
btw, I plan to add some more functionality to the bitmap window in the future. Maybe some "paint" type tools such as lines, fills, fonts placement etc.
I've been away for too long (que Soundgarden) - awesome job man!
Learning all the time...
I get an error when trying to download. Is the offline versions still available?
temporary glitch, try now...
Thank you!
Another update to version 0.61
- Add multi color operations to swap colur registers in selected characters
- Added multicolor horizontal flip in the Bitmap editor
- a few minor bug fixes
- pixel
- Website: http://hugbox.org/
Just started a simple new game with it but I'm missing two more rows and PAL colors [EDIT: found them…]. Having fun! Thanks!
Looking good
- joshuadenmark
- Big Mover
Super very impressed!
Few months ago I had plans to make something like this. But you already did it. Thumbs up! Looks great!
Arkanoid?
Now you just need to make it move...
- pixel
Yep! Thanks! It's supposed to become Arkanoid.
- pixel
Sorted, Sir! Sub-pixel accurate ball trajectory and collision detection (AKA perfect) with signed byte arithmetics.beamrider wrote:Now you just need to make it move...
Now watch the difference between the original sketch and what's coming out of Vice. I wished at least the single character boxes were closer to the original aspect ratio.
- majikeyric
