Vic 20 Screen and Character designer
Re: Vic 20 Screen and Character designer
This really is a brilliant utility, and now works fine in Firefox.
Another update to v0.36:
* Keyboard shortcuts for screen view
Ctl+C : Copy
Ctl+X : Cut
Ctl+V : Paste
Ctl+Z : Undo
Ctl+Y : Redo
* Coord display for screen view - row,col [(selectionwidth : selectionheight)]
Ctl+C : Copy
Ctl+X : Cut
Ctl+V : Paste
Ctl+Z : Undo
Ctl+Y : Redo
yet another update to v0.37
- add a "Swap Pair" facility to the char table.
I found this quite useful for desigining 2x2 tiles in conjunction with the copy/paste/flip/rotate functions. [works with the first two selected rows]
thanks everyone!
Any chance of adding import/export of picture files for MINIGRAFIK/MINIPAINT? Like this one:
(download link for paradroid.prg)
The file format is described in Appendix D of the MINIPAINT manual.
(And no, I'm not working on a Paradroid port... )
Please don't joke about that...if this happens I might die of excitement - I'm still working on my stuff here and that would be AWESOME!!!Mike wrote:Any chance of adding import/export of picture files for MINIGRAFIK/MINIPAINT?...
Learning all the time...
Import is done! - I've posted a new version with the Minipaint stuff in its own tab.Mike wrote:Any chance of adding import/export of picture files for MINIGRAFIK/MINIPAINT? Like this one:
Darkatx.. are you still with us?
If you load it with ",8" instead of ",8,1", it works.beamrider wrote:So I just tried to load "paradroid.prg" as posted above into Vice but it wouldn't display (basic seems to be corrupted). Undef'd, syntax error etc... Am I correct in thinking that it should be a stand-alone viewer?
As a matter of fact, MG picture files are saved with a load address of $10F1 - because that's the address they're also loaded back into memory by the @LOAD command, when MINIGRAFIK is loaded. To quote from the manual:
Emphasis added by me (and implies the ",8" ...)In case MINIGRAFIK is not active, or was not made available to the recipient of the image, the image still can be displayed by LOADing and RUNning the file. A BASIC SYS statement is provided at the begin of the file, which, when loaded to the normal BASIC start at $1201 (≥8K RAM expansion) calls a stand-alone display routine. The routine waits for a key press, and then resets the VIC.
The mechanism involved here does not work, when MINIGRAFIK already is loaded. In that case, use @LOAD instead, inside a program.
I can't do much about, that VICE autostarts programs with ",8,1".
OK, thanks!Mike wrote:If you load it with ",8" instead of ",8,1", it works.beamrider wrote:So I just tried to load "paradroid.prg" as posted above into Vice but it wouldn't display (basic seems to be corrupted). Undef'd, syntax error etc... Am I correct in thinking that it should be a stand-alone viewer?
Ok folks, I've just upload version 0.40 with support for MiniPaint import and export.
The new controls are in the MiniPaint tab and should be fairly self explanatory.
The "New MiniPaint Drawing" button sets up the required geometry and clears out the characater data to give a blank screen.
Tip: If you can't see what you're drawing because the character colour and screen colour are the same you can do a Fill with the mask set to just colour to set the intended char colour for an area as required.
Have fun!
Have fun!
.. surely you didn't expect me to RTFM?Mike wrote:To quote from the manual:
