Mine Sweep for the unexpanded VIC-20 (still work in progress):
https://dl.dropboxusercontent.com/u/795 ... p-VC20.prg
Enjoy,
Shaun.
Mine Sweep WIP.
Mine Sweep WIP.
Without context, we are only data.
Re: Mine Sweep WIP.
Now you should add joystick control and a check for a won game. It would also be good to 'teleport' away a mine if the first move lands on it. And a flood fill for areas of zero surrounding mines would be very nice.
Re: Mine Sweep WIP.
Thanks Mike,
I'm pretty bad at these logic games (especially playing them).
I have a joystick routine for the VC20, which is good.
This new version *should* do some of the things that you have suggested. Although I've yet to complete it without cheating. And yes, the program listing does need refactoring quite a bit.
Edit: If someone has a nice sound effect or short tune to play for the winner that they'd like to share then that would be good.
Regards,
Shaun.
Regards,
Shaun.
