ML routines in BASIC programs
I've never used ML routines in any game program, but the speed benefit is tempting. When I consider a joystick routine, it seems as if the ML code would take up more memory than a basic joystick code.
Is a memory efficient ML routine to read joysticks possible?
Let's say the code is to simply add 1, 22, -1, or -22 to a variable based on joystick input. The most memory efficient way to do this seems to be basic, right?
Re: ML routines in BASIC programs
How would you code it in basic? I'll try to improve it in ml.Jeff-20 wrote:I've never used ML routines in any game program, but the speed benefit is tempting. When I consider a joystick routine, it seems as if the ML code would take up more memory than a basic joystick code.
notes:
(joystick variables) D=37154:P=37151:Q=37152
Y=character location on screen,J=temp variable
Can this routine be SYSed for greater speed without using up more memory? It seems pretty tight as a basic routine. I made four seperate IF lines because it seems faster for the computer to refuse each conditional and jump to the next line rather than all the computations if I combined all four possible joystick inputs into one line.
1 POKE37154,255:P=37151:Q=P+1
routine:
2 M=PEEK(P): J=Y: IF(MAND4)=.THENJ=J-22
3 IF(MAND8)=.THENJ=J+22
4 IF(MAND16)=.THENJ=J-1
5 IF(PEEK(Q)AND128)=.THENJ=J+1
6 IFPEEK(J)>2THENPOKEY,33: Y=J: POKEY,2: GOTO2
I think you mean POKE 37154,127 in order to be able to read that last direction?
Anyway, I came up with something like this. There are a few more improvements over your routine, like rough boundary checking etc. You can remove it if it doesn't matter if you run outside of the video matrix.
I don't know if you really want to loop until you reach "B" or less. This routine assembles to 148 bytes, of which 32 are initialization, 2 byte (realy) may come from outside and 20 bytes are boundary check. It means the core joystick routine would be about 94 bytes, not counting the zero page locations used.
#processor 6502
#seg code
jp eqm $fb ; pointer $fb-$fc
yp eqm $fd ; pointer $fd-$fe
m eqm $ff
org 7168
lda #10 ; POKE 36879,10
sta $900f
lda #147 ; PRINT"[CLR]"
jsr $ffd2
lda realy ; If Y is meant to come from a Basic variable,
sta yp ; it gets slightly more complicated here..
lda realy+1
sta yp+1
main:
jsr joy
lda #100
wrl$:
cmp $9004 ; Some kind of delay loop, otherwise it gets
bne wrl$ ; much too fast
jmp main
joy:
lda #127
sta 37154
loop:
lda 37151
eor #$ff ; invert byte
and #28 ; bits 2-4 (4+8+16)
lsr ; shift down to bits 1-3 (2+4+8)
sta m
lda 37152
and #128
bne goon
inc m ; effectively turn on bit 0
goon:
lda yp
sta jp
lda yp+1
sta jp+1
ldy #4
compare:
lsr m
bcc nochg
lda dir-1,y
tax
clc
adc jp ; low/high
sta jp ; handle carry/overflow below
php
txa
bmi minus
plp
bcc nochg
inc jp+1 ; if positive addition, increase page
bcs nochg
minus:
plp
bcs nochg ; this was a bit tricky, how to detect backwards page break
dec jp+1
nochg:
dey
bne compare
lda jp+1
cmp #$1e ; boundary check
bmi out ; loop
cmp #$20
bpl out ; loop
cmp #$1f
bmi chk
lda jp
cmp #$fa
bcs out
chk:
lda (jp),y
cmp #2
bcc out
lda #33
sta (yp),y
lda jp
sta yp
lda jp+1
sta yp+1
lda #2
sta (yp),y
; bne loop
out:
rts
dir: .byte -1,22,-22,1
realy: .word 7680
This is my version, a BASIC/ML hybrid:
RUN this once. After this you can delete the lines 1-3. Never edit line 0. Your routine then reduces to:
0 POKE1,18:POKE2,16:REM{39 Z's}
1 FORT=0TO38:READA:POKE4114+T,A:NEXT
2 DATA173,31,145,74,74,41,7,170,173,32,145,73,128,41,128,10,125,50,16,8
3 DATA168,173,57,16,40,16,2,169,255,76,145,211,255,21,233,255,255,22,234
1 POKE37154,127
2 J=Y+USR(0):IFPEEK(J)>2THENPOKEY,33:Y=J:POKEY,2:GOTO2
Or for that matter in the space 673-767. Otherwise, a very clever routine Mike. It looks something like this when disassembled:
It appears the routine as listed relies on the end-of-line byte 0, so if positioned elsewhere in memory, it should be extended with the last zero byte as shown above.
LDA 37151
LSR
LSR
AND #7 ; bits are 1 for unused directions
TAX
LDA 37152
EOR #128 ; invert upper bit
AND #128
ASL ; shift it out as carry flag, and accumulator will contain zero
ADC dir,x
PHP
TAY
LDA dir+7 ; effectively zero
PLP
BPL out
LDA #255 ; make negative value
out: JMP $D391 ; convert integer in (A/Y) to FLPT in (FAC)
dir: .byte $FF,$15,$E9,$FF,$FF,$16,$EA,$00
I think the point is that once you run it and delete the lines after 0, you can save it to disk and get the code "inlined" in the basic program. The strange LDA to get a '0' is so you won't have any '0's in the code, messing up the basic rem line.TMR wrote:One minor point; the code could be dumped into the tape buffer, that'll reduce it's memory footprint considerably...?
Very neatly done!
- Occupation: farmer
Another 4 bytes saved
LDA 37151
LSR A
LSR A
TAY
LDA 37152
AND #128
ASL A ; shift it out as carry flag, and accumulator will contain zero
TAX
ADC dir,y
BPL out
DEX
out: TAY
TXA
I improved on this one:
Regards,
Wim.
LA107 LDA $911F
AND #$1C
LSR A
LSR A
TAY
LDA LA0FF-1,Y
LDX $9122
LDY #$7F
STY $9122
BIT $9120
STX $9122
BMI LA109
ADC #$01
LA109 JMP $DC3C
LA0FF .BYTE $15
.BYTE $E9
.BYTE $FF
.BYTE $FF
.BYTE $16
.BYTE $EA
.BYTE $00
Wim.
