In that case, the thread 'Display of TI$ in border (unex. or +3K)' might be worth a look.JavaJack59 wrote:A digital clock program. Read the jiffy clock and display it [...]
How do I get CC65 to include NO startup code?
Re: How do I get CC65 to include NO startup code?
technically, you dont need to recompile anything, just use -t none for no startup code and instead of main() use start():
(mind you, a lot of the C language relies on the startup code, so you better know what you are doing... at least properly set up the pointers to the software stack and heap. perhaps you also want a basic stub so you dont need to run the binary by SYS. and add a proper CBM load address to the output. etc etc )
$ cat test.c
void start(void)
asm("inc $d020");
$ cl65 -o test.bin -t none test.c
$ hex test.bin
0000 ee 20 d0 60
That looked promising, but I just ended up with a bunch of "Unresolved external" errors.groepaz wrote:just use -t none for no startup code and instead of main() use start():
I also briefly tried Quetzalcoatl for comparison, and it wouldn't build either ("Could not find runtime library uplrtime.obj")
Guess it's back to BASIC or klutzing my way through assembly.
Hi,
I use CC65 for VIC games and here is my simple cc65 project skeleton (unexpanded vic):
crt0.s:
..and main.c:
crt0.s:
.import _main
.import __RAM_START__, __RAM_SIZE__ ; Linker generated
.export __STARTUP__ : absolute = 1 ; Mark as startup
.include "zeropage.inc"
.segment "STARTUP"
.word $1001; Load address
.byte $0B, $10, $00, $00, $9E, '4','1','0','9',$00, $00, $00
lda #<(__RAM_START__ + __RAM_SIZE__)
sta sp
lda #>(__RAM_START__ + __RAM_SIZE__)
sta sp+1
jsr _main
typedef unsigned char byte;
#define SCREEN_ADDR (0x1E00)
#define COL_ADDR (0x9600)
byte* ptr_screen;
byte* ptr_color;
void main()
ptr_screen = SCREEN_ADDR;
ptr_color = COL_ADDR;
ptr_screen[1] = 0x01;
ptr_color[1] = 0x02;
ptr_screen[2] = 0x02;
ptr_color[2] = 0x03;
loop:
goto loop;
Misfit, your example is missing the necessary *.cfg file for the unexpanded VIC-20. It would also have been nice to provide a make file.
Nonetheless, I ran main.c through cc65 with '-t none', with this result (sorry for this slightly longer listing ...):
Dumbing down cc65 for this kind of use is really like using a hammer to turn a screw.
The equivalent assembly code (excluding the BASIC stub) would only use 4 LDAs and 4 STAs.
Well, you got 'Bertie the Ball' built and working with that method, but that verbose code above makes me wonder if it had been possible to pack the game into just +8K RAM instead (or providing more screens) - with pure assembly.
The lesson for me: it is actually possible to use cc65 in the way asked for in the OP. Not that I would want to use it like that, though.
<fx=goes off the stage></fx>
; File generated by cc65 v 2.13.2
.fopt compiler,"cc65 v 2.13.2"
.setcpu "6502"
.smart on
.autoimport on
.case on
.debuginfo off
.importzp sp, sreg, regsave, regbank, tmp1, ptr1, ptr2
.macpack longbranch
.forceimport __STARTUP__
.export _ptr_screen
.export _ptr_color
.export _main
.segment "BSS"
_ptr_screen:
.res 2,$00
_ptr_color:
.res 2,$00
; void __near__ main (void)
.segment "CODE"
.proc _main: near
.segment "CODE"
ldx #$1E
lda #$00
sta _ptr_screen
stx _ptr_screen+1
ldx #$96
lda #$00
sta _ptr_color
stx _ptr_color+1
lda _ptr_screen
ldx _ptr_screen+1
jsr pushax
ldx #$00
lda #$01
ldy #$01
jsr staspidx
lda _ptr_color
ldx _ptr_color+1
jsr pushax
ldx #$00
lda #$02
ldy #$01
jsr staspidx
lda _ptr_screen
ldx _ptr_screen+1
jsr pushax
ldx #$00
lda #$02
ldy #$02
jsr staspidx
lda _ptr_color
ldx _ptr_color+1
jsr pushax
ldx #$00
lda #$03
ldy #$02
jsr staspidx
L0015: jmp L0015
rts
.endproc
Yeah. I ended up with this:Mike wrote:missing the necessary *.cfg file
E:\coding\cc65\min>ld65 main.o vic20_minimal.o
ld65: Error: Memory configuration missing
project files
of course pure assembly code makes a smaller program, but I'm too lazy to create whole game without C-language.
Sometimes it's better to use more memory if it is the only way to create a finished product.
PERFECT.Misfit wrote:project files
For the uninitiated (read: me) what's the purpose of the "fill=yes" for "RAM" in the .cfg? I tried "fill=no" just to see what would happen and it seemed to work anyway.
Agreed.Misfit wrote:Sometimes it's better to use more memory if it is the only way to create a finished product.
Off to a decent start. Even pulling in memset and memcpy, I'm still under .5KB.
not really. he made a small crt0 which basically removes the heap, and doesnt use the interrupt chain stuff. both of which you dont want to use in a memory constrained environment anyway - i have done the same for all c64 programs i made with cc65.Dumbing down cc65 for this kind of use is really like using a hammer to turn a screw.
try with -Osir the generated code is large in some cases, but its not *that* bad reallyThe equivalent assembly code (excluding the BASIC stub) would only use 4 LDAs and 4 STAs.
Now that's really funny. With a slightly trimmed version of 'main.c' ...groepaz wrote:try with -Osir the generated code is large in some cases, but its not *that* bad really
void main()
*((byte *)(SCREEN_ADDR+1)) = 0x01;
*((byte *)(COL_ADDR+1)) = 0x02;
*((byte *)(SCREEN_ADDR+2)) = 0x02;
*((byte *)(COL_ADDR+2)) = 0x03;
loop: goto loop;
.setcpu "6502"
.smart on
.autoimport on
.case on
.debuginfo off
.macpack longbranch
.export _main
.segment "CODE"
.proc _main: near
.segment "CODE"
lda #$01
sta $1E01
lda #$02
sta $9601
sta $1E02
lda #$03
sta $9602
L0017: jmp L0017
.endproc
Maybe I'm just used to a C programming style that doesn't want to miss out on the standard library functions. On non-65xx platforms, that is. Of course C always offers you to create an own library, when the supplied implementation doesn't suit you.
oh, actually even with cc65 it is a very good idea to use the standard library as often as possible (usually the generated code will be smaller and faster than doing the same stuff inline) - however, its also a good idea to think twice about what you are using. as said malloc is often not a good idea and static buffers work better (as in: smaller footprint). also avoiding things like printf (because printf is actually file i/o, it pulls in tons of stuff - better use conio). those things are common things to do on other embedded platforms as well
I could do with some tips on converting the jiffy clock to integers 0-9. I'm assuming there's something in ROM that can do this for me ("print ti$") but I don't know how to make use of it.
I suppose you overlooked that reply:JavaJack59 wrote:I could do with some tips on converting the jiffy clock to integers 0-9. I'm assuming there's something in ROM that can do this for me ("print ti$") but I don't know how to make use of it.
And yes, there's a routine in ROM to do the same. However, that routine relies on float and string operations and requires one to set up a lot of zeropage locations, and memory areas in a certain way to operate correctly.Mike wrote:In that case, the thread 'Display of TI$ in border (unex. or +3K)' might be worth a look.JavaJack59 wrote:A digital clock program. Read the jiffy clock and display it [...]
Anyway, it should not be too difficult to infer from the disassembly how my own implementation of the conversion works. The jiffy clock is a 24-bit number, and it is incremented by one every 1/60 second (and reset to 0 as it reaches 24:00:00). There's a table with tens of hours, then hours, tens of minutes, minutes, tens of seconds and seconds in jiffies, which are (in that order) subtracted off a copy of the jiffy clock until the respective digit underflows to obtain a string equivalent to TI$ - which however is directly written to a part of the extended screen unreachable by the editor.
OTOH, there's always 'time.h' in the standard library, where time(), localtime() and asctime() also should be able to do the job.
Yeah, I did read it, but it wasn't immediately obvious to me how to translate it into vanilla C, since it relied on lower level things like the CPU overflow flag.Mike wrote:subtracted off a copy of the jiffy clock until the respective digit underflows
