Apologies for the delay, got sidetracked with other retro computer stuff.
I don't seem to get any errors at all from what I can tell, the program was running well over 15 minutes in a loop (video clip cut short deliberately).
Youtube vid attached. Let me know if I stuffed it somehow by modifying the wrong lines.
Couple of typo's but the "1" key is a bit dodgy on my keyboard.
[youtube]k0qKEzCbPUI[/youtube]
Doom Video glitch problem "SOLVED"
Re: Doom Video glitch problem "SOLVED"
It's taken me an awful lot of time and brain energy to finally figure out the cause of this problem, and in a way I am pretty
annoyed at myself as to the cause, but at the same time I have learn't bucketloads about how the Vic-20 works so definitely not
wasted time in that respect.
I even went down the unlikely path of redesigning the chip and block select part of the 32k memory expansion to use a 74hc21 as a
4 to 1 AND gate for the chip select, and a 74hct00 as the block select. At the moment the unused pins are floating, so I'll deal with that
if and when I get any problems. I had an idea that separating the ouputs of chip select and block select to different IC's might help.
Made no difference of course but I was clutching at straws. A different brand of Ram chip also made no difference, Alliance vs Cypress.
I have spares for every single IC in the Vic-20 so tried sitting new chips on top of their equivalent, that made no difference. Ram tests all passed
with flying colours. My Vic-20 had no problems with Kweepa's game "The Keep" so that proved there couldn't really be a video related problem as
both games appear to the untrained eye to have a similar style of drawing the graphics.
Where I mentioned this earlier "Another weird behaviour is I was testing the Text Colour change in basic by pressing CTRL-Number keys and occasionally got letters instead."
I got the same behaviour in Vice when I tried that a couple of days ago.
As it turns out there wasn't a single fault anywhere whatsoever inside my Vic, every part working perfectly.
The Moral of the story and Answer to the problem is "DO NOT USE A 65C02" processor as a 6502 replacement. As I got a couple of these very cheap
on Ebay to try and resolve intermittent crashing issues and left it installed as they run nice and cool.
So I'll probably order a couple of R6502's as spares, if there are any compatibility issues there that anyone knows about please let me know?
Off topic, how are you capturing the video above?
Sent from my iPhone 6 Beta using Tapatalk
I have an Avermedia H727 capture card in my PC, it has Analog and Digital tv. Composite, s-video, component, and Hdmi inputs.
I captured that through s-video from my Vic-20 with the Avermedia software which is absolute rubbish except capture functions produce a decent result.
The Digital TV is so bad I installed Mediaportal which is a Lot better.
I don't think the 65C02 does undocumented opcodes, does it? They are being used in Doom if I am correct: Doom code improvement-discussionImperious wrote:The Moral of the story and Answer to the problem is "DO NOT USE A 65C02" processor as a 6502 replacement. As I got a couple of these very cheap
You are correct, the 65C02 doesn't do undocumented opcodes, there were also other changes.
Doom was the only game I tried that gave problems, although there is still a lot of software I haven't tried.
Interestingly whilst doing some research about this I found out that when the Apple2C was released it broke some of
the software, which is because it used a 65C02.
- Kweepa
- Occupation: Game maker
Yeah, I use ASR in the column renderer. See the sources on github:
https://github.com/Kweepa/vicdoom/blob/ ... olumnAsm.s
lines 70, 71.
Seems like a poor choice now, since it didn't make things appreciably faster...
lines 70, 71.
- Omega Star Commander
I wonder if VICE will support swapping out a 6502 with a 65C02 to reproduce this mod?
