Getting "too slow" messages in LINUX VICE
- Omega Star Commander
Re: Getting "too slow" messages in LINUX VICE
You said "if", I do not. Pretty much the same is not the same. SDL rendering, window, and full screen management is altogether different. Even VICE ini variables distinguishes between the two, which is most annoying. How about some convergence there to make your point matter?
I'll check again. I probably got the version number wrong....anyway, it's probably whatever is the latest official stable VICE for Linux.groepaz wrote:interesting, is that an official repo? must be the first distro that has packages of intermediate versions...ral-clan wrote:This is Lubuntu 14.04. I'm using VICE 2.4.6 downloaded through Lubuntu's Software Centre.
Hey, big difference between them. 2.4.6 is a major uplift over 2.4.0.
Re: Getting
no, it isnt. with no hardware acceleration both would use your OSs software blitting, with acceleration both would use GL. the only difference would be some gluecode, which is really negligible. certainly it makes no differences regarding performance (except you are running it without x11 - but thats a completely different thing)Pretty much the same is not the same. SDL rendering, window, and full screen management is altogether different.
that would be 2.4 then - hence i am wonderingit's probably whatever is the latest official stable VICE for Linux.
Re: Getting
Yup....it's 2.4:groepaz wrote:no, it isnt. with no hardware acceleration both would use your OSs software blitting, with acceleration both would use GL. the only difference would be some gluecode, which is really negligible. certainly it makes no differences regarding performance (except you are running it without x11 - but thats a completely different thing)Pretty much the same is not the same. SDL rendering, window, and full screen management is altogether different.that would be 2.4 then - hence i am wonderingit's probably whatever is the latest official stable VICE for Linux.
brent@Brent-Lubuntu:~$ xvic
VIC20 kernal patched to 901486-07.
Error - mouse_cursor_grab: bad params
Reading configuration file `/home/brent/.vice/vicerc'.
VIC20 kernal patched to 901486-06.
*** VICE Version 2.4 ***
OS compiled for: Linux
GUI compiled for: GTK+
CPU compiled for: Pentium Pro
Compiler used: GCC-4.8.2
Current OS: *nix
Current CPU: Intel Pentium 4/Pentium D/Pentium Extreme Edition/Celeron/Xeon/Xeon MP
Welcome to xvic, the free portable VIC20 Emulator.
