ROM calls and other tricks
J.E.E.K.
Website: http://klasek.at/8bit
Re: ML Optimization tips and tricks
Post by J.E.E.K. »
wimoos wrote: Wed Dec 12, 2012 4:27 amRemove NOP’s
This list could be extended by
  • Hold flag in bit 7 of a location, so you can check the flag by "BIT flag" followed by "BMI/BPL destination" keeping A untouched, clear the flag with "LSR flag". If carry is set by an condition before, use "ROR flag" to set the flag.
  • Operations without temporarily save the accumulator to memory:
    • To subtract the value in A from location's value ( (mem)-A ) use EOR #$FF; SEC; ADC mem (negate A with two's complement and simply add).
    • Merge some bits from A into a memory location using EOR mem; AND #mask_bits_taken_from_acc; EOR mem; STA mem.
Reason: (near) full-quote shortened. Please refer to the OP by following the blue arrow link.
bjonte
Handy toggle
Post by bjonte »
Sometimes you want to toggle a memory location between two values. This can be done using EOR. The value to use for EOR can be constructed with eor in the assembler (operator ^ in this example).
// constants to toggle between
const value1 = 55
const value2 = 170
// set initial value
lda #value1
sta memaddr
// toggle
lda memaddr
eor #value1 ^ value2
sta memaddr
MrSterlingBS
Re: ROM calls and other tricks
Post by MrSterlingBS »
Sometimes I used
STY $ZP
… some code
LDY $ZP
instead of
TYA
PHA
… some code
PLA
TAY
A little bit faster and shorter code if you have some ZP registers free.
wimoos
Occupation: farmer
Re: Handy toggle
Post by wimoos »
bjonte wrote: Mon Jul 04, 2022 2:34 pm Sometimes you want to toggle a memory location between two values. This can be done using EOR. The value to use for EOR can be constructed with eor in the assembler (operator ^ in this example)
To elaborate on this, consider the following code snippet that I used in WimBasic:
	EOR  #$82      	 ; token NEXT ?
	BEQ  LA3D6
	EOR  #$9C ^ $82  ; token CLR
	BEQ  LA3F3
	EOR  #$8E ^ $9C  ; token RETURN
	BEQ  LA46C
	JMP  $CF08 ; ?SYNTAX ERROR
LA3D6	TAY ; clear Y
LA46C
The code is entered with a tokenized value in A, that needs to be checked against three possible values. The code, following the selection benefits from having a value of zero in A (or could benefit from the carry-flag not having been changed).
Regards,
Wim.
