A good example are sorting algorithms. Bubble-Sort, while easily implemented (I can write that routine down straight from memory) is a bad algorithm - such that it really should be forbidden to teach it to those new to programming. I just use it here, to state the point, to compare it with Quick-Sort.
Quick-Sort is more complicated to program. I confess I always have to look it up in a book, when I need to implement it myself. Luckily C has a built-in Quick-Sort.
First comes the example. Replace GOSUB 50 in line 13 with GOSUB 20 to test Bubble-Sort instead of Quick-Sort. N is specified in line 11.
I use the variant of Quick-Sort, that sorts the smallest sub-array first. This minimizes stack usage. DIMS(31) is enough to sort up to 65535 elements.
Quick-Sort also works with String-Arrays (use A$(), A$, and X$ instead). If you want to sort other arrays alongside A(), place the additional swap operation(s) between lines 55 and 56.
10 DIMS(31):SP=0:REM ** STACK FOR QUICK-SORT
11 N=10:DIMA(N)
12 FORT=0TON:A(T)=RND(1):NEXT
13 T1=TI:L=0:R=N:GOSUB50:T2=TI
14 FORT=0TON:PRINTA(T):NEXT
15 PRINTT2-T1
16 END
18 :
19 REM ** BUBBLE-SORT
20 IFR<=LTHENRETURN
21 F=0:FORT=LTOR-1:IFA(T)>A(T+1)THENA=A(T):A(T)=A(T+1):A(T+1)=A:F=1
22 NEXT:IFFTHEN21
23 RETURN
29 :
49 REM ** QUICK-SORT
50 IFR<=LTHENRETURN
51 I=L:J=R:X=A((L+R)/2)
52 IFA(I)<XTHENI=I+1:GOTO52
53 IFA(J)>XTHENJ=J-1:GOTO53
54 IFI>JTHEN57
55 A=A(I):A(I)=A(J):A(J)=A
56 I=I+1:J=J-1
57 IFI<=JTHEN52
58 IFJ-L<R-ITHENS(SP)=I:S(SP+1)=R:SP=SP+2:R=J:GOSUB50:GOTO60
59 S(SP)=L:S(SP+1)=J:SP=SP+2:L=I:GOSUB50
60 SP=SP-2:L=S(SP):R=S(SP+1):GOTO50
These are the run times in clock ticks:
Quick-Sort
N Run 1 Run 2 Run 3 Run 4 Run 5
10 56 65 60 61 59
30 230 221 231 211 207
100 837 881 867 849 858
300 3029 3169 3054 2969 2960
1000 12032 11954 11941 12553 12266
Bubble-Sort
10 66 47 93 82 64
30 563 501 684 633 627
100 6268 6918 6837 7474 6622
300 62476 57756 ... you get the idea
1000 not tried, expected time ~600000..700000 clock ticks.
