SD2IEC question?
SD2IEC question?
Is it okay to remove or insert the SD card while the Vic-20 is running? Until now, I've always turned the Vic-20 off to do that.
Re: SD2IEC question?
I do it and it's never been a problem. In principle, it's no different to removing a floppy disk while the computer is still on.Boray wrote:Is it okay to remove or insert the SD card while the Vic-20 is running? Until now, I've always turned the Vic-20 off to do that.
are we sure the sd2iec firmware flushes all the buffers and leaves the filesystem in a consistent state every time the led goes off?
Pallas - OPByte
http://www.opbyte.it/vic20/
I can confirm that it does. It also rests the internal state when a new card is inserted.pallas wrote:are we sure the sd2iec firmware flushes all the buffers and leaves the filesystem in a consistent state every time the led goes off?
Feel free to eject/insert SD cards with sd2iec-based devices with abandon.
Jim
Thanks!
Does it support sub directorys?
Like C16 -> Games, Demos
Vic20 -> Games, Demos
Yep!
@cd:directory
@cd:..
etc.
@cd:directory
@cd:..
etc.
You can browse around in the file structure with http://www.boray.se/commodore/vicmenu.html
(or with CBM file browser).
Thanks. I better check if my Megacart has those
Seems that older Mega-Cart didnt have this utility yet.
