Vicman *1970
Posts: 247 Joined: Sat Jun 30, 2007 5:48 am
Post
by Vicman *1970 » Mon Aug 26, 2013 9:53 am
orion70 wrote: HAWKMEN
di E. Aguilar trad. e adatt. di F. Sarcina
Data entry by Unknown (found on old tape)
Paper Soft anno I Anno I N.13 (14/09/1984).
Istruzioni
Note:
Modificata la riga 63000 per permettere il caricamento della seconda parte dal drive attuale (tape o disk)
Riga originale:
63000 POKE198,5:POKE631,78:POKE632,69:POKE633,87:POKE634,13:POKE635,131:END
Righe modificate/aggiunte:
63000 PRINT"{CLR}{4 GIU'}L
O "CHR$(34)"HAWKMEN 2"CHR$(34)","MID$(STR$(PEEK(186)),2,2):PRINT"{6 GIU'}RUN{HOME}"
63010 FORZ=0TO9:POKE631+Z,13:NEXT:POKE198,10
Hi orion70,
your modified *.d64 file didn't work for me....
get the message : "fermare il nastro.
premere run-stop e restore prima del run"
can not run the game. any idea ?
Posts: 4341 Joined: Thu Feb 02, 2006 4:45 am
Post
by orion70 » Tue Aug 27, 2013 1:08 am
Hello Vicman, I split your post, as the thread was intended for posting typed-in games only
Will try the game and let you know ASAP!
Post
by orion70 » Tue Aug 27, 2013 2:00 am
Here I am - it was my fault, I didn't modify the second program (Hawkmen 2) on the disk to fit the new loading system properly.
Unfortunately, I noticed that the joystick doesn't work - I'll have to debug this
I updated the downloadable file, if someone wants to help me with this issue (wonder if I ever tried the game back then before uploading it).
Vicman *1970
Post
by Vicman *1970 » Tue Aug 27, 2013 2:26 am
Thanks for the info.
And sorry...can't help with debugging....
but maybe this helps a little :
The "original" Game was published in in the Magazine Compute 1983/06 (The Hawkmen of Dindrin)
I have a *.d64 file wich is also corrupt, and a
working *.prg-file.
http://www.youtube.com/watch?v=zIMYxCOHfwQ
(maybe it's a fix by mayhem)
It's inside mayhem's GBv0.3
So you should ask him. Or i can send this prg to you via E-Mail...
Post
by orion70 » Tue Aug 27, 2013 3:16 am
I should have the original file somewhere at home.. Will check it, thank you.
Posts: 3027 Joined: Mon May 24, 2004 7:03 am
Post
by Mayhem » Tue Aug 27, 2013 3:38 am
Yeah, I can forward it on if need be. There was an issue, someone did fix it at some point heh...
Post
by orion70 » Tue Aug 27, 2013 4:11 am
If you upload it somewhere, I can simply compare the two listings, or take the working one and translate the text parts in Italian (it was an Italian magazine after all
). Else, drop me a line in PM, and I'll send you my private mail. Thank you.
Post
by orion70 » Thu Aug 29, 2013 4:01 am
Now a working copy has been uploaded
(thanks to Mayhem's GB20)
