Unit is far enough along that I can share. Comments on schematic are appreciated. I have tested the previous version of this design (with a '173 instead of the '273) for operation and banking and all looks OK. This one adds a '273 instead to use an active low reset line, and allow ROM to be turned off.
http://jbrain.com/vicug/gallery/vicmidi ... tic?full=1
VIC MIDI Cartridge
- Schema
- factor
Success! The Clavinova CVP407 likes the new code drop. I didn't see any misses until I started paying with the MIDI channels on the KB while it was playing a pre-recorded song, and I don't think that counts.
If there's a way to get a channel where all of the voices come on at the respective notes, I'll have my wife play a song with the unit and record it.
Jim
Jim
- Schema
- factor
Final design. Features:
Jim
- 16450 based UART, can be replaced with 16550 if desired
- Up to 512kB of FLASH ROM mapped to BLK5 (64 banks), probably will ship with 128kB (16 banks).
- Can be reprogrammed from the VIC
- requires just 16 IO locations in IO memory map.
- Bank register sits at base+15
- IO2/IO3 selectable
- MIDI IN,OUT,THRU
- IN/OUT Activity LEDs
- RESET button
- RS232 drivers and DB9 onboard for RS232 cart usage
- Can be selected to hook MIDI IN to MIDI OUT if desired
- /IRQ support
- FLASH ROM disable
- FLASH need not be installed
- RS232 need not be installed
- MIDI need not be installed (if used as RS232 only)
- RS232 TxD and RxD can be set to connect to each other
- Switching from RS232 to MIDI use can be done via SW, no switches or parts replacement needed.
Jim
