[**Commercial Release Is Now Available**] Realms of Quest IV
I programmed most of the wireframe graphics display for the dungeon:
malcontent
Post by malcontent »
I think the view could be stepped back a little. That is, you see the boundary of the cell you're in just at the edges of the frame, so you are aware if there are corridors to the sides of you.
malcontent wrote:I think the view could be stepped back a little. That is, you see the boundary of the cell you're in just at the edges of the frame, so you are aware if there are corridors to the sides of you.
It already does that. In the screenshot I posted above, the player just happens to have walls to each side.
Wilson
Post by Wilson »
Your progress is always so fun to follow, Ghislain! I'm loving the old-school vibe.
Wilson wrote:Your progress is always so fun to follow, Ghislain! I'm loving the old-school vibe.
Thanks. Old school is cool. The wireframe graphics aren't as colorful as they were in the previous, but they provide a different atmosphere.
With that, I'm uploading Alpha demo 1 for Realms 4 for everyone here to try out:
https://sites.google.com/site/gdbsite50 ... ects=0&d=1
Obviously, it's not even close to completion. But in this demo, you can create up to 8 characters as well as buy, sell and equip items. And finally, you can leave the castle and move around in the first level of the dungeon.
16K of RAM expansion is required.
Ghislain wrote:I programmed most of the wireframe graphics display for the dungeon: [...]
The perspective of the dungeon in this screenshot looks rather strange, so to speak. :?
pallas
Post by pallas »
The perspective looks a bit like that of a strong wideangle.
IN response to the wireframe graphic perspective. I can explain it as follows:
REALMS 1+2 used a 2D overhead view of the dungeon where you could only see walls immediately right next to you:
|X|
REALMS 3 used a 3D perspective but you can only see the halls and doors in a straight line from you:
|X|
REALMS 4 gives you a wider line of sight, where you can see walls, doors and hallways around the front of you:
_____
_   _
 |X|
So there's a wider range of view. It might appear a bit confusing, but I did modify the graphics slightly in the demo after the screenshot was posted. Check the demo to see how it's like to navigate through the dungeon.
Today I programmed the routines to display the stairs and reveal secret doors when the wizard's eye or true sight spell is invoked.
There will be a lot more fun things in the dungeon like locked doors, NPC encounters, spinners and teleporters.
darkatx
Post by darkatx »
I downloaded it and created and equipped but it appears to not load up when I choose to leave and go to the dungeon?
Learning all the time... :)
Kweepa
Occupation: Game maker
Post by Kweepa »
I too got a red screen forever (well, for a minute or so at 6200%).
I only created one character. Do I need a whole party?
darkatx
Post by darkatx »
That's what I thought too and same story... :(
Try turning on true drive emulation, or using Vice 2.4 (with or without true drive).
Kweepa
Post by Kweepa »
Huh, that worked!
Looks good. Some of the views seem a little strange (missing walls etc) but it could be that the map is very sparse.
darkatx
Post by darkatx »
I had turned on true drive emulation (mind you I had enabled it after the initial load but before 'Leaving') but it was a older version of VICE. Worked fine on 2.3 with true drive emulation on. :)
Yeah, I like the view - works for me and you seem to have adjusted it so that it is similar in perspective to ROQ3.
Looks very promising indeed :D
