VIC-20 Software Releases of 2013
Name: Vic Menu V26
Author: Boray
Released: August 25, 2013
Requirements: VIC-20 with diskdrive or an IEC device. For the JSLOAD starter, a memory expansion is required.
Disk Menu V26
http://www.boray.se/commodore/vicmenu.html
This version combines the two previous versions (24IEC and 25SJLOAD) and adds some enhancements.
Extract the zip archive to your IEC root dir.
If you want to use the menu with SJLoad, then start with LOAD"//:S",8
If you want to use the menu stand alone, then LOAD"//:M",8
If you want to use the menu on a normal 1541 drive, then just use the file M.
New features:
The menu now starts up at the first page rather than the last one. I felt this was more natural.
You can now walk with the cursor from one page to the other up and down without having to press space.
Whats with LOAD"//:S",8? Why not just LOAD"S",8? Well if you are in the root dir, both works just fine, but loading "//:S" works from any sub dir and will show that directory directly.
I timed V26 with SJLOAD against cbm file browser with SJLOAD they are equally fast at reading directories even though vic menu displays the files while reading.
However, if you prefer cbm file browser, then you are welcome to use my SJLOAD-loading starter with it. All you have to do is to load "S", change line 12 to load the file browser instead of "M". Then save it as for example "SFB".
Author: Boray
Disk Menu V26
New features:
Name: Vic Menu V27
Author: Boray
Released: August 28, 2013
Disk Menu V27
A bug-fix: Cartridge images of a certain name length was loaded as a normal non-cart program because of unexpected screen line behaviour. This bug must have been in there for a very long time.
Tip worth mentioning again: If you want to switch text case while the directory is being loaded, then hold down shift and then press the commodore key, because if you press the commodore key alone, the dir loading is stopped.
Sorry for releasing so many versions so close!
Author: Boray
Disk Menu V27
Name: Realms of Quest IV: 4-Level Demo Version
Author: Ghislain
Released: September 1, 2013
Requirements: VIC-20 with 16K minimum memory expansion is required. 24K is recommended for better performance (for less disk usage) and greater 3D graphical perspective. A disk drive is also required.
Description: Demo version of the upcoming Psytronik release for Realms of Quest IV where the first four levels of the dungeon can be explored. The attached PDF manual is still a work in progress, but serves as a preview of how the printed version will look like when the whole game package is published.
The long-awaited follow-up to Realms of Quest III is almost completed. As I continue work on finishing Ultimate Quest for the Commodore 64 (intended to be on Side 2 of this Psytronik release), I make the first four Dungeon levels available to everyone.
Realms of Quest IV has the following features:
-10 Dungeon Levels with various riddles, traps and NPC characters who can aid you on your quest (4 levels only for Demo Version)
-Over 100 monster graphic portraits (50 in Demo Version)
-10 races and 12 classes to choose from as you assemble 8 players for your party
-60 magic spells
-Over 135 items (weapons, armor, shield, gems, jewels, potions and scrolls)
-3 game fonts to choose from
The enemy this time are the mysterious Time Lords who threaten the reign of the fairer creatures above the earth. Befalls thus you, brave adventurers, to battle the labyrinth below all our feet, and ensure for yet another generation, that the evils and chaos do not rise. How it can be so, that this peace last forever, none knows. All one knows, is in the Dungeon, lay riches, glory and the immortality of your name.
Download.
Discuss.
YOUTUBE VIDEO.
Author: Ghislain
-60 magic spells
Download.
Discuss.
YOUTUBE VIDEO.
Name: Vic Menu V28 deluxe
Author: Boray
Released: September 7, 2013
Requirements: VIC-20 with diskdrive or SD2IEC. For the JSLOAD starter, a memory expansion is required.
Disk Menu V28 deluxe
Requirements: Vic-20 with diskdrive or other serial storage device.
Preferred: Vic-20 with expansion ram, a reset button and SD2IEC.
Installation and usage:
Start with LOAD"//:S",8
If you want to use the menu on a normal 1541 drive, then just use the file SJ/M or SJ/MD (deluxe version for expanded vic).
News in V28:
* An expanded vic will be downscaled to unexpanded mode when starting an unexpanded program. (This works much as my PRG Starter). So no more plugging and unplugging carts. Be sure to reset your computer before starting S again afterwards, or you will still be in unexpanded mode. (Note that you have to have ram in block 0 to be able to run 3K expanded programs.)
* The starter "S" now gives you the option to run the menu without SJLOAD.
* The starter will start the previous version (SJ/M) if you have less than 4000 bytes free, or else it will start the deluxe version (SJ/MD).
* The batch delete function is back in the deluxe version. Press "D" on all files you want to delete. They are marked with an "-". Then press Shift-D to delete them all in one go.
* You can now config SJLOAD from the deluxe menu (see where it is in memory in case you forgot, move it or disable it).
* You can clear first half of block 5 to get rid of an old autostarting cart image.
* You can now press "L" to jump to the last page of files.
* The line showing free blocks was removed allowing another line of filenames. The number of free blocks wasn't correct on SD cards anyway.
* The help screen was reworked and expanded.
Note: From the turbo/memory screen you can press "U" to "unexpand now". You normally don't have to do this unless you try to load an unexpanded program which contains the wrong starting address.
Author: Boray
News in V28:
Author: Victragic
Released: September, 2013
Requirements: Vic (PAL only) + 16k expansion, joystick
This is an attempt to create a new version of David Crane's brilliant Atari 2600 classic Pitfall! for the Vic 20. Use the joystick to control Harry through 255 screens, avoiding obstacles and collecting treasures.
The game utilises raster effects to generate the playfield (tree trunks, ground, holes, pits and the ladder are all background) and dynamic colouring of Harry and several items (cobra, wall, fire) to create a more colourful screen and reduce the instances of colour-clash.
One heads-up, watch the jumps on the crocodiles, as Harry's leap is slightly more than the distance between the crocs' heads.
The game can be downloaded from :
https://docs.google.com/file/d/0BypQg4Q ... sp=sharing
Discuss here.
Author: Victragic
Discuss here.
3^4 is 81.0000001
Name: How Many 8K
Author: Boray
Requirements: Vic 20 with 8K expansion and a disk drive (for the high scores).
Do you remember the 7.77MHz version? Well, I decided I wanted to play it on a real Vic-20, so here is a new version:
http://www.boray.se/commodore/howmany8K.html
It's compiled with Austro compiler, optimized for compilation, adjusted delays etc. I hope it will make it to your Vic as well.
Author: Boray
Name: Boray's SD2IEC music player
Author: Boray
Released: 15 September, 2013
Requirements: Unexpanded PAL Vic-20 + SD2IEC card reader
(or alternatively PAL VICE emulation).
http://www.boray.se/commodore/boraysd2iecplayer.html
This is roughly 60 minutes of digitized music for your Vic-20. The audio is 4 bit 4kHz mono so don't excpect great sound quality. (~ old AM radio).
This program might break a couple of world records: The longest sample ever played on a Vic-20? (my 25 minutes long Amzidus). It's probably also the largest Vic-20 application ever made. It's 6.8 MB in size.
If you want to play this on a NTSC Vic-20, or just play around a bit, you can change two delays set at basic line 15/16. Higher values = slower.
Author: Boray
Author: tlr
Released: 14 September 2013
Requirements: Cross-platform
cbmtools is a collection of tools operating on cbm-style prg-files:
chd - 'hd' like hex dump for cbm files
cld - cbm binary linker (opt executable output)
cgen - cbm self-checking test file generator
cpch - cbm binary patcher
(cgen and the RLE option of cld is currently c64 only)
Download: cbmtools 0.6
Author: tlr
Name: Boray's SD2IEC music player V2
Author: Boray
Released: 27 September, 2013
Requirements: Unexpanded Vic-20 + SD2IEC card reader (or VICE emulation). Should work on both PAL and NTSC (I hope).
http://www.boray.se/commodore/iecplay2/
Improvements over the previous version:
* Improved playback quality.
* 4 selectable playback routines.
* New/more music, better converted.
* 1 hour and 17 minutes of total playing time.
* You can play all songs in one go and then loop back to the beginning to play forever.
* One version that works (or should work) on both PAL, NTSC, VICE and the real hardware.
* Included convert program and instructions on how to convert your favourite music to the vic-20.
* More Commodore commercials.
Author: Boray
Name: Boray's SD2IEC music player V2.1
Author: Boray
Released: 29 September, 2013
Improvements over V2.0:
You can now use the joystick during playback: Up = Fast forward (playing fast with audio), Down = Play slow, Fire = Skip to the next song/return to the menu if you play a single song. This only works with the default playback routine. Note that these speeds are not at all as synced as normal playback speed. The fast forward mode plays every second sample and the slow mode just puts in an extra delay. I also replaced one of the songs, "Nothing to say" because I thought it didn't sound very good. I replaced it with a tune called "Time Traveler".
Author: Boray
- Kweepa
- Occupation: Game maker
Name: Yoho and Howay
Author: Kweepa
Released: 2 October, 2013
Requirements: Vic-20 + 24k with disk drive
Description: Scott Adams/Brian Howarth adventure collections
Eighteen classic Scott Adams squeezed onto one VIC-20 disk, and the eleven Brian Howarth Mysterious Adventures on another.
Download Yoho.
Download Howay.
Discuss.
Author: Kweepa
Download Yoho.
Download Howay.
Discuss.
Author: Victragic
Released: 8 October, 2013
Requirements: Unexpanded Vic-20 + Joystick
Description: Maze Craze style game
A single-player game based on the Atari VCS game 'Maze Craze' and others. Get to the exit on the right side of the screen, then back to either exit on the top-left or bottom-left before your time runs out. Avoid the black hounds, hitting one will knock 10 seconds off your time.
The game gets progressively harder each maze with the enemy hounds speeding up, and the number of hounds increasing in number. Your player will also begin to slow on each return run.
100 points are rewarded for each return home, plus one point for each second remaining.
Download
Discuss
Author: Victragic
Download
Discuss
3^4 is 81.0000001
Name: Always the same, Never the same
Author: Boray
Released: 18 October, 2013
A new music album, available for the Vic-20:
http://www.boray.se/commodore/always_th ... _the_same/
(4 bit, 4 kHz)
And as high quality music download:
http://boray.bandcamp.com/album/always- ... r-the-same
(24 bit, 44.1 kHz)
Author: Boray
(4 bit, 4 kHz)
(24 bit, 44.1 kHz)
Author: tlr
Release Date: 2013-10-31
Requirements: VIC-20 (PAL) with 32Kb expansion.
Download: fcbpaint-0.6.zip
Description:
This is an editor for a special software defined graphics mode with 168*192 pixels with 8x4 char color and inline color splits.
News:
- pictures can now be exported as runnable binaries.
- colors in the upper and lower border area can be changed.
- added directory function.
- added a selectable direct color mode. in direct color mode selecting
a color on the keyboard immediately updates the current setting under
the cursor.
- fixed annoying glitch when panning using ijkl.
- <bs> in the viewer returns to the menu.
- added menu option to quit the program.
- general bug fixes.
Screenshots:
See also Exin's excellent picture here: Vic picture
Discuss this release: here
Author: tlr
Description:
News:
the cursor.
Screenshots:
Re: VIC-20 Software Releases of 2013
Author: Misfit
Release Date: August 26th 2013
Requirements: Unexpanded VIC-20 + Disk Drive + Joystick
Tested : VICE 2.2 and real VIC-20 (PAL)
Download: D64
Description: Ludum Dare 48h game competition entry
Discuss: here
Author: Misfit
Download: D64
Discuss: here
