Favorite Tools?
- JohnnyRockets
- Occupation: IT Manager
Favorite Tools?
Hi!
For ASM programming I have been using DASM and Crimson Editor.
For BASIC, I have no real tool/editor?
What does everyone else use for ASM/BASIC programming?
Thanks!
JR
JR
- Occupation: farmer
For editing and debugging Basic programs on the VIC itself, you could use Programmers' Aid. In Windows environment there is BasEdit.
For assembly programming and debugging on the VIC you could use VIC Monitor. As a crossassembler, DASM is ok.
WimBasic also provides for several editing and debugging features (next to a wealth of extra runtime commands and functions).
As a crossassembler I use TASM.
Regards,
Wim.
Regards,
Wim.
- JohnnyRockets
I use Eclipse+WUDSN IDE and ca65/ld65 for ASM cross-development.
According to their homepage, WUSDN IDE now also supports running ca65 directly, but I did not check it yet, because I use GNU make to run the assembler&linker. WUDSN IDE also supports DASM & XASM.
Edit: typo.
Edit: typo.
I use Aart Bik's Mac/Win/Lin2c64 assembler.
http://www.aartbik.com/MISC/c64.html
Aart Bik himself is still active on the KIM:
https://plus.google.com/104142700609491 ... mdW6mFQ9iR
- JohnnyRockets
- JohnnyRockets
