Denial Forum Index Denial
The Commodore Vic 20 Forum
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
New Release: KWEEPOUT
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    Denial Forum Index -> Games
View previous topic :: View next topic
Author Message
Kweepa
PostPosted: Sun Jun 17, 2012 6:01 pm    Post subject: New Release: KWEEPOUT Reply with quote
http://www.kweepa.com/step/vic20/games/kweepout.prg
A version of Breakout (oops!) written in BASIC for the unexpanded VIC.
This was an experiment to see how much I could fit into a BASIC program.
Loosely inspired by this presentation:
http://www.youtube.com/watch?v=Fy0aCDmgnxg
Let me know what you think!
Back to top
View user's profile Send private message
TBCVIC
PostPosted: Mon Jun 18, 2012 2:30 am    Post subject: Reply with quote
Very nice! Though that's not Pong, that's Breakout.
_________________
Ola Andersson
Back to top
Kweepa
PostPosted: Mon Jun 18, 2012 8:00 am    Post subject: Reply with quote
DOH!
Back to top
PostPosted: Mon Jun 18, 2012 9:48 am    Post subject: Reply with quote
Kweepout sounds a bit wrong though Wink
_________________
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Mon Jun 18, 2012 10:32 am    Post subject: Reply with quote
HAHAHA! That would get my attention a bit faster though!
I look forward to playing this!
_________________
Back to top
View user's profile Send private message Visit poster's website
PostPosted: Mon Jun 18, 2012 6:05 pm    Post subject: Reply with quote
Nice one! Always pleasantly surprised by your versatility! Action (Doom), Text Adventure (Cometfall), Jump & Run (Blue Star) and now you even rival the Jeff's BASIC skills!
I managed to finish level one but in level two the screen started going crazy. The blanks in the background were replaced with another char, and after a few minutes even the ball was gone. Probably string-variables creeping into the character definitions (since those are written from the top down). Looks like you did not protect your character-definition by something like
Code:
POKE56,28:CLR
like most programs do.
Back to top
Kweepa
PostPosted: Mon Jun 18, 2012 6:26 pm    Post subject: Reply with quote
Gah!
I deliberately didn't do that, because I needed all the space below for the program and variables.
I'm only using one string variable, A$, and during gameplay it's only used to hold the score, so I'm not sure how it keeps growing... Any ideas? There should be 248 bytes free between the space character and the screen.
Back to top
GreyGhost
PostPosted: Mon Jun 18, 2012 7:20 pm    Post subject: Reply with quote
Could you use some of that free space to save the score there. Then read it like you would a low byte - high byte. I haven't played the game yet so I'm not sure how high the score can go, but 3 bytes can hold a number over 15 million.
score = peek(byte 1)+peek(byte 2)*256+peek(byte 3)*65536
Of course it will take a bit of memory to calculate.
if byte 1>256 then byte 2 = byte 2 + 1
if byte 2 >256 then byte 3 = byte 3 + 1
_________________
Rob
Back to top
PostPosted: Tue Jun 19, 2012 12:49 am    Post subject: Reply with quote
I really should get an sd2iec device so I can try these new games that are coming out. A couple of years ago I made it a point to transfer all of the 'New Releases' via USB to 1541 cable. Emulation is fine, but when you have a real hardware setup, you tend to just want to actually play the games on real hardware.
So I'm going to order an sd2iec device right now. Maybe a second one for my C64 as well. I'm sort of tired of always trying to keep track of what game or program is on which disk, etc.
_________________
Back to top
matsondawson
PostPosted: Tue Jun 19, 2012 1:49 am    Post subject: Reply with quote
Ah, on my emulator it's immediately broken. Must be because I launch the program by loading it into ram, then sys'ing it.
http://www.mdawson.net/vic20chrome/vic20.php?load=http://www.kweepa.com/step/vic20/games/kweepong.prg&machineType=pal
Back to top
PostPosted: Tue Jun 19, 2012 2:49 am    Post subject: Reply with quote
Yes, I see the problem. You use:
Code:
A$=STR$(K)
However, this will always reserve new space in memory for A$, until the memory is full and the garbage collection kicks in. To avoid this you can force a garbage collection by caling the FRE(0) function:
Code:
F=FRE(0)
I also noticed you poke the new character set into RAM with your program. You may just include the character set with the file and start with
Code:
POKE45,x:POKE46,y:CLR
where x and y are the true ending of the program. However this might go against your "pure" BASIC agenda
Back to top
GreyGhost
PostPosted: Tue Jun 19, 2012 6:06 am    Post subject: Reply with quote
Also, if you change:
Code:
1 v=36874:fori=.to5:readx:pokev+i,x:next
76 data0,0,0,0,15,14
to:
Code:
1 v=36874:pokev,0:pokev+1,0:pokev+2,0:pokev+3,0:pokev+4,15:pokev+5,14
You will save 10 bytes. Unless their is another reason you did it like that.
You can also put the new character data starting at location 7424.
Then:
Code:
poke52,29:poke56,29:clr
Your first character defined would have to be a space character, and your custom characters will start with the value 32(space), but it will save 256 bytes. And you still have the regular set when reversed.
Hope that is explained ok.
EDIT:
2 more bytes, you have "thengoto" in lines 63 & 64.
_________________
Rob
Back to top
Kweepa
PostPosted: Tue Jun 19, 2012 7:36 am    Post subject: Reply with quote
Thanks for the detailed analysis!
I had no idea there was lazy garbage collection! You (I) live and learn!
Including the character set definitely goes against my "true" agenda which is a single, type-in-able, file.
For setting the sound and border, unless I'm miscounting, using a loop and data statement (which I combined with existing data) takes 4 bytes less than 6 pokes.
I tried moving the character set further up in memory but without the FRE(0) the definitions got massacred instantly. I know how to fix it now though Smile
THENGOTO? Oops! Amateur hour!
I'll knock up a new version soon.
Oh, and for the emulated version, I realize now that I'm using the space character undefined, so it's liable to end up garbage. In VICE it seemed to be ok.
Back to top
PostPosted: Tue Jun 19, 2012 9:08 am    Post subject: Reply with quote
You should! For me, everything is straight to a real Vic now. It's great!
_________________
Back to top
GreyGhost
PostPosted: Tue Jun 19, 2012 1:35 pm    Post subject: Reply with quote
Opps. guess early morning hours must be to blame. I am getting a different result than I did last night.
Anyway, gratz on getting it working correctly.
_________________
Rob
Back to top
Display posts from previous:
Post new topic   Reply to topic    Denial Forum Index -> Games All times are GMT - 6 Hours
Page 1 of 3
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
