After last years release of the MFLI-mode for the PAL VIC-20, I was looking for new frontiers on the VIC. I knew the NTSC VIC-20 had an interlace feature, however apart from a small font-demo by Marko Mäkelä I could not find any other software using this.
With the things I learned in the MFLI-mode I thought about what might be possible on an NTSC-machine, but first I had to get the hardware AND make sure I could display it on my monitor. eslapion was kind enough to sell me a working VIC-20 and ship it over to Germany. This one being the CR-model I could use a european standard VIC20/C64 power supply on it. To be able to actually display a picture I found a cheap analogue converter that translates NTSC to PAL60, thus not messing with the picture digitally, which was essential in checking the interlace-effect worked.
Some weeks after I got the machine I had a simple display routine running. This was actually simpler to code than last years MFLI-mode for PAL, because much of the knowledge could be applied, and the actual graphic layout was a little simpler as well, see here:
Picture for even lines:
d0 = dynamic line 0 ($0158-$01ff)
d1 = dynamic line 1 ($00b0-$0157)
nx = non dynamic lines (n1-n22)
Update d0
Update d0
Update d1
Line 01e:d0 Update d1 char 63- 43 ($01ff-$0158) video $1000-$1014 charmem at $0000 $c8
Line 02e:d1 Update d0 char 42- 22 ($0157-$00b0) video $1015-$102b charmem at $0000 $c8
Line 03e:n1 Update d0 char 66- 86 ($1210-$12b7) video $102a-$103e charmem at $1000 $cc
Line 04e:d0 Update d1 char 63- 43 ($01ff-$0158) video $103f-$1053 charmem at $0000 $c8
Line 05e:n2 Update d1 char 87-107 ($12b8-$135f) video $1054-$1068 charmem at $1000 $cc
Line 06e:d1 Update d0 char 42- 22 ($0157-$00b0) video $1069-$107d charmem at $0000 $c8
Line 07e:n3 Update d0 char 108-128 ($1360-$1407) video $107e-$1092 charmem at $1000 $cc
Line 08e:d0 Update d1 char 63- 43 ($01ff-$0158) video $1093-$10a7 charmem at $0000 $c8
Line 09e:n4 Update d1 char 129-149 ($1408-$14af) video $10a8-$10bc charmem at $1000 $cc
Line 10e:d1 Update d0 char 42- 22 ($0157-$00b0) video $10bd-$10d1 charmem at $0000 $c8
Line 11e:n5 Update d0 char 150-170 ($14b0-$1557) video $10d2-$10e6 charmem at $1000 $cc
Line 12e:d0 Update d1 char 63- 43 ($01ff-$0158) video $10e7-$11fb charmem at $0000 $c8
Line 13e:n6 Update d1 char 171-191 ($1558-$15ff) video $10fc-$1110 charmem at $1000 $cc
Line 14e:d1 Update d0 char 42- 22 ($0157-$00b0) video $1111-$1125 charmem at $0000 $c8
Line 15e:n7 Update d0 char 192-212 ($1600-$16a7) video $1126-$113a charmem at $1000 $cc
Line 16e:d0 Update d1 char 63- 43 ($01ff-$0158) video $113b-$114f charmem at $0000 $c8
Line 17e:n8 Update d1 char 213-233 ($16a8-$174f) video $1150-$1164 charmem at $1000 $cc
Line 18e:d1 Update d0 char 42- 22 ($0157-$00b0) video $1165-$1179 charmem at $0000 $c8
Line 19e:n9 Update d0 char 234-254 ($1750-$17f7) video $117a-$118e charmem at $1000 $cc
Line 20e:d0 Update d1 char 63- 43 ($01ff-$0158) video $118f-$11a3 charmem at $0000 $c8
Line 21e:n10 Update d1 char 0- 20 ($0000-$00a7) video $11a4-$11b8 charmem at $0000 $c8 -> here ldx for switch to $1800 and nop
Line 22e:d1 Update d0 char 42- 22 ($0157-$00b0) video $11b9-$11cd charmem at $0000 $c8
Line 23e:n11 Update d0 char 0- 20 ($1800-$18a7) video $11ce-$11e2 charmem at $1800 $ce
Line 24e:d0 char 63- 43 ($01ff-$0158) video $11e3-$11f7 charmem at $0000 $c8
Picture for odd lines:
Update d0
Update d0
Update d1
Line 01o:d0 Update d1 char 63- 43 ($01ff-$0158) video $0200-$0214 charmem at $0000 $88
Line 02o:d1 Update d0 char 42- 22 ($0157-$00b0) video $0215-$022b charmem at $0000 $88
Line 03o:n12 Update d0 char 21- 41 ($18a8-$194f) video $022a-$023e charmem at $1800 $8e
Line 04o:d0 Update d1 char 63- 43 ($01ff-$0158) video $023f-$0253 charmem at $0000 $88
Line 05o:n13 Update d1 char 42- 62 ($1950-$19f7) video $0254-$0268 charmem at $1800 $8e
Line 06o:d1 Update d0 char 42- 22 ($0157-$00b0) video $0269-$027d charmem at $0000 $88
Line 07o:n14 Update d0 char 66- 86 ($1a10-$1ab7) video $027e-0$292 charmem at $1800 $8e
Line 08o:d0 Update d1 char 63- 43 ($01ff-$0158) video $0293-$02a7 charmem at $0000 $88
Line 09o:n15 Update d1 char 87-107 ($1ab8-$1b5f) video $02a8-$02bc charmem at $1800 $8e
Line 10o:d1 Update d0 char 42- 22 ($0157-$00b0) video $02bd-$02d1 charmem at $0000 $88
Line 11o:n16 Update d0 char 108-128 ($1b60-$1c07) video $02d2-$02e6 charmem at $1800 $8e
Line 12o:d0 Update d1 char 63- 43 ($01ff-$0158) video $02e7-$02fb charmem at $0000 $88
Line 13o:n17 Update d1 char 129-149 ($1c08-$1caf) video $02fc-$0310 charmem at $1800 $8e
Line 14o:d1 Update d0 char 42- 22 ($0157-$00b0) video $0311-$0325 charmem at $0000 $88
Line 15o:n18 Update d0 char 150-170 ($1cb0-$1d57) video $0326-$033a charmem at $1800 $8e
Line 16o:d0 Update d1 char 63- 43 ($01ff-$0158) video $033b-$034f charmem at $0000 $88
Line 17o:n19 Update d1 char 171-191 ($1d58-$1dff) video $0350-$0364 charmem at $1800 $8e
Line 18o:d1 Update d0 char 42- 22 ($0157-$00b0) video $0365-$0379 charmem at $0000 $88
Line 19o:n20 Update d0 char 192-212 ($1e00-$1ea7) video $037a-$038e charmem at $1800 $8e
Line 20o:d0 Update d1 char 63- 43 ($01ff-$0158) video $038f-$03a3 charmem at $0000 $88
Line 21o:n21 Update d1 char 213-233 ($1ea8-$1f4f) video $03a4-$03b8 charmem at $1800 $8e
Line 22o:d1 Update d0 char 42- 22 ($0157-$00b0) video $03b9-$03cd charmem at $0000 $88
Line 23o:n22 Update d0 char 234-254 ($1f50-$1ff7) video $03ce-$03e2 charmem at $1800 $8e
Line 24o:d0 char 63- 43 ($01ff-$0158) video $03e3-$03f7 charmem at $0000 $88
You might wonder how the resolution 168x384 came about. Well, the horizontal 168 is the resolution that allowed for updating the 3 colors in $900f and $900e per line while still being able to do the updates for the dynamic lines fast enough. 384 was just the natural limit because of multiple memory constraints, not the least of which was the 1K color-RAM. 168x384 uses 1008 of those 1024 bytes. I wanted to have a separate color-RAM for each interlace-half-picture.
Once the mode was set up, I needed pictures. I converted an old .PGM-converter from Mike for hires-pictures and Mike himself provided an improved version of his converter. Maybe he can tell you more about this. I provide both the old and color-conversion-improved version of his converter in my archive, since I found playing around a little with the pictures and its gamma values will sometimes provide a better result.
That's about it. Of course I still have some ideas left for possible graphic modes for the NTSC and PAL VIC-20, but I'll keep those ideas for another post in this series.
