Hi,
i've updated the Commodore VIC20 TOSEC-Collection.
It has now a size of about 100 MB.
many programs are renamed, and many are added to TOSEC.
(also all GB_VIC v0.2 files are added)
still need to add many type-ins. (and of course, the "new" games from Mayhem's GB_VIC20 v0.3)
btw. any release-date for this ?
however,
i've uploaded it to Underground Gamer (so if you are a member, help seeding),
and here:
http://www.multiupload.com/A87XKXXO0C
cheers,
Vicman
Commodore VIC20 (TOSEC-v2011-12-29)
- Vic 20 Devotee
eCC-Imagepack-Designer
Done: Vic20, N64, Philips VG-5000-G7000-G7400, SordM5, Amstrad GX4000
Progress: Atari 8bit, Enterprise 64/128, Dosbox
- Mayhem
- High Bidder
Thanks! Just wondering: Why are all files zipped inside of the zip file? No file will use less than 8K on a standard NTFS drive anyway.
- Vic 20 Devotee
sorry for late reply......Boray wrote:Thanks! Just wondering: Why are all files zipped inside of the zip file? No file will use less than 8K on a standard NTFS drive anyway.
well, TOSEC-SET's are always created/available as zipped files.....
and i put all (zipped) files in one zip-file for better uploading....
tosec vic-20 2011 was added to search.cbm8bit.com when it was released a few months back.
You can search for files using the archive specific feature in the advanced search menu.
enjoy
Shane.
enjoy
Shane.
http://search.cbm8bit.com Commodore 8bit Search!
- Omega Star Commander
That search engine is pretty awesome! Thanks for pointing it out.
