Hi.
I'm using GETIN to read the keyboard.
If I type too quickly, I can sometimes get one of the keys "stuck", so that pressing keys after that will also press the stuck key. Pressing the stuck key manually fixes the problem.
Does this sound familiar? Is it a VICE bug or a VIC bug, does anyone know? I'm hoping a VICE bug - seems more likely I think...
VICE and key jamming?
Re: VICE and key jamming?
Yes. For me it happens in VICE 1.16 but also in VICE 2.3, especially with the Shift or CBM keys. When I hold one of them down, select one of the VICE menus inbetween, and during that let off the key, VICE doesn't register that. Rather, it thinks the key is still held down, and it is 'un-stuck' by typing on it again.Kweepa wrote:Does this sound familiar?
It's mainly a matter of the keyboard to VIA mapping. For example, on a real VIC-20, I quite often get:
LOAD"LOAD
PRESS PLAY ON TAPE
