The Vic I've been using for the last couple of years is playing up with two different Mega Carts. As soon as I turn the computer on, the machine automatically selects A World at War and keeps doing that when I press reset. I tried my second MC and had exactly the same problem.
I tried the Vic without anything in the expansion port and was able to run a short type-in program without any problems.
Anyone know what might be causing the problem and if it can be fixed?
Vic Cartridge Problems
There is a 1uf capacitor associated with 555 timer IC (which controls reset timing) within your Vic-20.
This electrolytic capacitor is likely dried out & outside of tolerance.
Replacing it should clear the problem.
Problem solved. It turned out that one of my joystick buttons was jammed and that was what was causing the software to jump ahead of me.
I tried about five different Vics with both MCs and kept getting the same problem and then I pulled the joystick out and everything was fine.
I have to say that I'm greatly relieved because this is my best Vic-20 and is about as good as it gets in terms of both cosmetic appearance and audio/video performance.
Thanks to everyone who tried to help.
