groepaz wrote:According to Groepaz Gideon's implementation of the 6502 is not 100% compatible but nobody could indicate a specific piece of software it has problems with.
the various test programs that fail are not specific enough? ok then
No. Test programs are not representative of how the CPU is used by software, especially legacy software, in the VIC-20 arena and I strongly feel you argue for the sole purpose of misleading people.
Test software look for every little nooks and crannies that software in the VIC-20 arena simply does not use.
Also, on the C64, all that's needed to activate or deactivate the built-in CPU is the pull high or low the DMA line. Not so on the VIC.
Only you consider it necessary to have a MOS 6502 on a SuperCPU for the VIC and for frivolous reasons.
I ran the rockwell CPU on my VIC and I can find NOTHING created before 1989 that will cause problems. Robotic liberation works and so does JiffyDOS.
The SuperCPU V3 is incompatible with more than only the Fastload cartridge.
Yea, I am tired... that should've been the SuperPLA V3...
But it still doesn't work with 2 different C64 mainboards. Its a serious deal.
