German Magazine - Type-Ins - 64er
This magazine was spun off "Happy Computer" once the publishing company realized there was a large demand for a Commodore-based magazine. In the early days of 64er it also featured some VIC-20 games and apps. Later when the magazine was nearly all C64 they issued 2 special-issues for C16 and VIC-20 in 1986.
Luckily most of the type-ins where offered on disc as well and images of these could be found on the net. For some earlier issues these are not available however, and I aim to fill those gaps. Again, I will leave out some of the applications unless they have some interesting value. Not really much use for an UNNEW or disc-copy-program nowadays.
April, 1984:
http://www.tokra.de/vic/64er/8404/8404.zip
KALENDER (+16K): Prints a montly calendar when you have a printer connected. Will calulcate weekdays and holidays, and you can make notes for each day.
RENNFAHRER (unexpanded VIC): Move you car with L and R. Don't forget to get fuel every 5 laps.
April, 1984:
May, 1984:
http://www.tokra.de/vic/64er/8405/8405.zip
SCHMATZER (unexpanded VIC): Get the points, avoid the monster... Move with joystick or , . J M
Note: Thanks to geopete for typing this in initially. I've amended a small typo I found he made when typing this in.
GRAFIK (+8K): A small paint-program with a neat feature. You can record a paint-routine by pressing F3 - paint what you want, press F3 again and recall your movements with F5. Otherwise the program is not very polished. For example: You may not paint over the borders as this will delete the machine-language part of the program.
SUPERGRAPHIK (unexpanded VIC): Paints a sine-curve on an unexpanded VIC. Noteworthy because it's a very small program and instead of setting up a bitmap it redefines characters dynamically and as such allowing a larger screen area to be filled with graphics (as long as enough characters are still blank)
June, 1984:
http://www.tokra.de/vic/64er/8406/8406.zip
UNDERGROUND (+16K): Was awarded type-in of the month. A multi-level game. First move through the elevators without hitting your head. Then collect all numbers in the correct order. The position will change every few seconds or if you press fire. Next collect the black creatures called "piplips" in the cave. The maze will constantly change when you pick up one. Be sure to get them all. Next another, more difficult, elevator level. Finally you got to avoid two moving objects. The difficulty here is that you cannot stop your movement until you hit a wall. There is a cheat to finish this level much more easily though. Try to figure it our for yourself.
GHOST MANOR (unexpanded VIC): Flee the manor. Use joystick or keys A Z B M N (O to start). At some places you need to do double-jumps. Do these by pressing fire and then the direction immediately afterwards (not at the same time).
Note: This game was later stolen with mildly changed graphics and re-issued in Compute Mit 10/85
MOVEMASTER (+8K): Tool to create a short animation (up to 47 pictures). I uploaded the manual as PDF, since it would take to long to explain.
LOGIC DISASSEMBLER (+8K): Tool to watch an assembler-program in process. Whenever a jump or branch occurs, you can follow it by pressing Y or skip it by N. If you want to exit press X.
July, 1984:
http://www.tokra.de/vic/64er/8407/8407.zip
RAETSEL (+8K): Creates a word-puzzle on the screen, where you have to find the words inside the jumble. You can enter your own words in DATA-lines 700-999.
CROUSSAIDER (unexpanded VIC): Use your joystick to prevent the always advancing aliens to reach your planet. New level every 33 seconds. Watch our for the large motherships in level 3.
August, 1984:
http://www.tokra.de/vic/64er/8408/8408.zip
ESCAPE (unexpanded VIC): Escape the alien spaceships.
KUDIPLO (+3K): Curve sketching with your VIC. Requires a VC1520 Printer Plotter to work.
PRINAT_RESTOREN (all VICs): Adds 3 commands to BASIC:
£x,y - deletes from line x to y - e.g. £0,22 clears screen
@x,y"string" - prints string at position x,y - e.g. @0,0"VC-20"
RESTORE n - RESTORE-command now accepts a line number to set the data pointer
September, 1984:
http://www.tokra.de/vic/64er/8409/8409.zip
SCHIEBESPIEL (all VICs): Sort the letters vertically instead of horizontally. When you think you are finished press F1.
October, 1984:
http://www.tokra.de/vic/64er/8410/8410.zip
EPEDEMIC (+8K): In the distant future (1989) a meteor storm is heading for Earth. To make things worse, it carries viruses that will infect humanity. You have to make decisions each day to keep the catastrophe as small as possible. First you can produce medicine, then you can shoot down meteors with rockets, you can administer medicine to areas that have been hit or you can nuke a continent to prevent the disease from spreading. Keep human losses to a minimum!
Note: A very dark strategy-game probably inspired by the movie "War Games" and the cold war in general. Please also note the german instructions. Maybe someone wants to translate the game itself?
DISKETTEN-ORGANISATION (+8K): Tool to do all kinds of disk operations
VIDEO-VORSPANN (unexpanded VIC): Create a "professional" studio-intro for your VHS-tapes. Enter data, then press F7 to go through some images. Totally useless nowadays
Yes pleeeeeeaseee.... Someone please translate the game and its instructions! Too bad I don't know German...tokra wrote:Note: A very dark strategy-game probably inspired by the movie "War Games" and the cold war in general. Please also not the german instructions. Maybe someone wants to translate the game itself?
November, 1984:
Note: Games for the VIC were becoming rare in the 64er magazine by now. Instead you got interesting apps and tools. They had some great games in the special issues, though, so stay tuned.
http://www.tokra.de/vic/64er/8411/8411.zip
LATERNA MAGICA (unexpanded VIC): Do animations with the VIC. German manual
PSEUDO-SPRITES (+8K): Tool to create and animate sprite-like objects with UDGs. German manual
BETRIEBSSYSTEM-ERWEITERUNG (+24K): Some tools for programming in BASIC. Yes, it really has no splash-screen. German manual
SUPERGRAFIK II (unexpanded VIC): An expanded version of SUPERGRAPHIK from the May issue. This one does so on a screen size of 200x256 on an unexpanded VIC. This is done by dynamically redefining characters. You need to have enough blank areas left, so this is no bitmap mode.
December, 1984:
http://www.tokra.de/vic/64er/8412/8412.zip
MATHEMATICAL BASIC (+24K - or RAM in BLK3): A BASIC-extension with focus on mathematical funtions. German manual
FAST TAPE (all VICs): A turbo tape for the VIC20. Use !S to save and !L to load.
January, 1985:
http://www.tokra.de/vic/64er/8501/8501.zip
CHECKSUMMER (all VICs): The type-in aid from this issue onwards. Only for completists.
Thanks for the manual! I had the disk image once downloaded from arnold, but no copy of the instructions, but without instructions you effectively cannot use the extension. No point in guessing around how the syntax of the commands and functions might be, even if you can get a list of all available keywords by taking a quick look in the VICE monitor ...tokra wrote:MATHEMATICAL BASIC (+24K - or RAM in BLK3): A BASIC-extension with focus on mathematical funtions. German manual
'EPEDEMIC' looks like a promising candidate to be enhanced with MINIGRAFIK ...
