Holy...!
I only got as far as level 42!
New Release: THE KEEP
Re: New Release: THE KEEP
This game is sooooo great! But I feel that I need a pause function. After 20-25 levels or so, my back hurts and I get hungry. It would be great to be able to pause it (i.e freeze the lamp status). Possible?
- Kweepa
- Occupation: Game maker
I don't remember how many bytes free there are, but in principle a pause should be easy to add.
When the map is up it doesn't look like the lamp burns, so you could try leaning something lumpy on the map key.
Change the map key to shift. You could then use shift/lock as a pause.
Rob
I'm curious to try ... but where do I get it from? The old download link doesn't work.
Greetz
Greetz
- Kweepa
It's here:
http://www.kweepa.org/step/vic20/thekeep.prg
Source (I think ):
http://www.kweepa.org/step/vic20/thekeep.zip
Source (I think ):
