PNGtoUDG
Kweepa
Occupation: Game maker
PNGtoUDG
Post by Kweepa »
Hi,
I had some UDGs designed in PNG, laid out as 8x8 tiles, so I wrote a little program to extract data statements for them.
http://www.kweepa.com/step/vic20/PNGToUDG.exe
You just place it in a directory containing PNGs and it writes data statements to the standard output.
> dir /b
> PNGToUDG > udg.txt
> type udg.txt
defb 0, 1, 255, 128, 127, 33, 31, 255
defb 0, 1, 255, 128, 127, 31, 33, 255
defb 44, 65, 63, 63, 63, 37, 224, 255
Requires the .NET framework 3.5. Sorry!
Boray
Musical Smurf
Re: PNGtoUDG
Post by Boray »
Kweepa wrote: Requires the .NET framework 3.5. Sorry!
What are you sorry about? It's a privilege to have .NET installed! :wink:
I used a similar program to create the UDG data for MINIPAINT, even though I did the design in MS Paint as *.bmp, and then a conversion in IrfanView to *.pgm, so my image library (see 'image.c' and 'image.h' here) could process the bitmap:
The grey/white checkerboard pattern shows the 8x8 character bounding boxes. Then this C program converts it into EQUB directives for the inline assembler of HI BASIC:
#include <stdio.h>
#include <stdlib.h>
#include "image.h"
int main(int argc, char *argv[])
  IMAGE *image=image_load("status");
  FILE *stream=fopen("result.txt","w");
  int byte[8],x,x2,y,y2;
  for(y=0; y<4; y++)
    for(x=0; x<14; x++)
      for(y2=0; y2<8; y2++)
        byte[y2]=0;
        for(x2=0; x2<8; x2++) byte[y2]=2*byte[y2]+(b_pixel(image,x*8+x2,y*8+y2)<128);
      fprintf(stream," EQUB %3d:EQUB %3d:EQUB %3d:EQUB %3d:EQUB %3d:EQUB %3d:EQUB %3d:EQUB %3d\n",
                       byte[0], byte[1], byte[2], byte[3], byte[4], byte[5], byte[6], byte[7]);
  exit(EXIT_SUCCESS);
It would have been a much hairier task to design this in a normal character editor, let alone squared paper. :P
Anyway, this thread should go into 'Emulation and Cross-Development'. Could one of the mods please move it to there?
