However before that idea came to fruition I mused about enhancing the just released MAXIGRAFIK-mode to 8x8 color blocks instead of the 8x16 blocks of MAXIGRAFIK. I realized that this would need a complete new addressing scheme (again) since the video-RAM would be twice as large (832 bytes instead of 416) and as such lots of graphics data would have to be handled in the zeropage for speed. Before I had time to think more about it, Mike came up with this layout:
$1000 .. $133F Screen
Display: Update:
Line 0 $1340 .. $140F (1) Line 2
Line 1 $1410 .. $14DF (1) Line 2
Line 2 $0000 .. $00CF Line 27
Line 3 $14E0 .. $15AF (1) Line 5
Line 4 $15B0 .. $167F (1) Line 5
Line 5 $0000 .. $00CF Line 27
Line 6 $1680 .. $174F Line 8
Line 7 $1750 .. $181F Line 8
Line 8 $0000 .. $00CF Line 27 + Line 28
Line 9 $1820 .. $18EF Line 11
Line 10 $18F0 .. $19BF Line 11
Line 11 $0000 .. $00CF Line 28
Line 12 $19C0 .. $1A8F Line 14
Line 13 $1A90 .. $1B5F Line 14
Line 14 $0000 .. $00CF Line 28
Line 15 $1B60 .. $1C2F Line 17
Line 16 $1C30 .. $1CFF Line 17
Line 17 $0000 .. $00CF Line 30
Line 18 $1D00 .. $1DCF Line 20
Line 19 $1DD0 .. $1E9F Line 20
Line 20 $0000 .. $00CF Line 30
Line 21 $1EA0 .. $1F6F Line 23
Line 22 $00D0 .. $019F Line 23
Line 23 $0000 .. $00CF Line 30 + Line 31
Line 24 $01A0 .. $026F Line 26
Line 25 $0270 .. $033F Line 26
Line 26 $0000 .. $00CF Line 31
Line 27 $1340 .. $140F (2) Line 29
Line 28 $1410 .. $14DF (2) Line 29
Line 29 $0000 .. $00CF Line 31
Line 30 $14E0 .. $15AF (2) Line 0,1
Line 31 $15B0 .. $167F (2) .
(Line 32) .
(Line 33) .
(Line 34) bis
(Line 35) .
(Line 36) .
(Line 37) .
(Line 38) Line 3,4
Update from $1340 .. $167F (832 Bytes, ABS) needs 4992 cycles, works within 9 char-lines.
Update from $0000 .. $00CF (208 Bytes, ZP) needs 1040 cycles, works within 2 char-lines.
In the end just a few hundred CPU-cycles of 22152 total per picture where left.
Try it out for yourselves:
http://www.tokra.de/vic/208256c.zip
Download unzip, then do this (preferrably within VICE at Warp-Mode - PAL - at least 24K)
load"208256c-stub.prg",8,1
poke44,112:poke112*256,0:new
load"test256.prg",8
run
Once I finished this FLI-mode was already on the way and was posted in October, but I did not post the MAXIGRAFIK-COLOR mode back then since Mike said he would adapt the BASIC-expansion for it and maybe add the CHAR-command (since now 8x8 color chars were possible). But he was busy with his incredibly cool VFLI-mode and so this was put back.
I (once again) thought I had reached the VIC's limit, but then about a week before Christmas I had another idea how to increase the raster-split color-switches to each line. How this could be done when I just mentioned there was no raster-time left will be explained in Part 11. Soon
