Hi everyone.
The instruction manual for the Cardkey/1 external numeric keyped
mention a "CK/1A Keypad Adapter" which is supposed to increase the software copatability of the keypad by making a direct connection to the computer some how.
Can anyone provide some information on this adapter?
If you have one, could you post some images?
Cardkey/1 Keypad Adapter (requesting info)
Keypad info
I'll have to find mine in the closet somewhere. I unhooked it from the machine it was attached to, as it had issues not related to the keypad.
Basically, you unplug the keyboard connector from the mlb, plug that cable into the ten key pad, and in turn plug the new assembly into the mlb, feeding the ribbon cable out of the computer case.
