CBM prg Studio
Re: CBM prg Studio
A bug maybe... The letter 'V' shows up 3 or 4 bits higher on a text line than the other characters.
Rob
Re: CBM prg Studio
Hi Rob,
Yes that's a weird one. It seems that it's only the letter V and only if it's in a comment. I tried to contact the author (I didn't write the edit control) a long time ago but he seems to have disappeared. I do have the source code for it though so I'll take a look when I get a chance. I'm busy getting prg studio ready for a new release in about a week.
Arthur.
Arthur.
Re: CBM prg Studio
Why Arthur is not posting this here, I have no idea.
17th June 2016 - CBM prg Studio Version 3.8.0 released.
I hope he hasn't forgotten about us.
Re: CBM prg Studio
Sorry about that, I'll have to sack my publicist!
Re: CBM prg Studio
Well it's long overdue but the latest version (v3.9.0) of CBM prg Studio is finally ready to download. There's a raft of bug fixes as well as these new features:
Download
- TARGET directive.
- Logical operators with 'ifdef'.
- Complex expressions for constants.
- Command window.
- Import SEQ files.
Download
- Vic 20 Hobbyist
- Website: http://www.tonyrocks.com
- Occupation: IBM Watson Engr
Re: CBM prg Studio
Just installed it! Thanks for your continued development!!
Re: CBM prg Studio
I've been testing it out. The build speed is very nice. The ongoto/sub numbering gets correctly changed when renumbering. Very happy!
Re: CBM prg Studio
That's great news, thanks for letting me know.
Arthur.
Arthur.
Re: CBM prg Studio
My tests also confirm that all the reformat /renumber problems have been fixed.R'zo wrote:I've been testing it out. The build speed is very nice. The ongoto/sub numbering gets correctly changed when renumbering. Very happy!
The 'import settings' issue remains however.
I reinstalled the beta files you sent me just to check it wasn't a windows issue and they both picked up the previous settings. V3.9.0 fails to do this and manual import of a saved config does nothing.
Re: CBM prg Studio
Did you install 3.9.0 in the same directory as 3.8.0? The .NET framework should use the old app settings as long as you haven't deleted/uninstalled the previous ones first, and you haven't changed the installation directory. Admittedly the upgrade procedure isn't great but at least you don't have to do it that often these days.vicist wrote:The 'import settings' issue remains however.
Re: CBM prg Studio
OK.
Just to make sure, I uninstalled everything.
Installed 3.8.0 and populated all the relevant fields.
Installed 3.9.0 to same folder (overwriting 3.8.0) and all settings are inherited.
I kept the previous versions separate so that I could always fall back on them if something didn't work properly. I suppose the best thing to do now is make a copy of the folder and install new versions into that instead.
Perhaps you could remove the info in the installer telling you to 'uninstall previous versions first' as this prevents the settings being inherited.
Many thanks for all the work you have put into bug-fixing this excellent program.
Re: CBM prg Studio
That's great, I was sure that this worked!vicist wrote:Installed 3.9.0 to same folder (overwriting 3.8.0) and all settings are inherited.
Good idea, I'll remove it.vicist wrote:Perhaps you could remove the info in the installer telling you to 'uninstall previous versions first' as this prevents the settings being inherited.
Re: CBM prg Studio
Well it's long overdue (again!) but the latest version (v3.10.0) of CBM prg Studio is finally ready to download. There's a raft of bug fixes as well as some useful new features.
The complete list of bug fixes and new features is on my website. Enjoy!
http://www.ajordison.co.uk/download.html
Re: CBM prg Studio
Your download link here is not working but I was able to get I off of your webpage. I'll test it out and give you some feedback.
