Profiling
- Kweepa
- Occupation: Game maker
Profiling
I was thinking about adding a simple profiler extension to VICE. But before I do that, does anyone have a pointer to a ready-made solution?
My thought was to have a menu item to turn on and off profiling. When profiling:
static int clocksForInst[256];
static int clocks[NUM_CHUNKS][65536];
static int chunk = 0;
static int chunksize = 0;
#define CHUNK_SIZE 500000
clocks[chunk][pc] += clocksForInst[*pc];
++chunksize;
if (chunk >= CHUNK_SIZE) { ++chunk; chunksize = 0; }
And then use the cc65 map file to find the functions.
Obviously it wouldn't be hierarchical, but I can live with that.
++chunksize;
Such a big array should be allocated with malloc() on an 'int **' instead. What value range would be expected for NUM_CHUNKS?Kweepa wrote:static int clocks[NUM_CHUNKS][65536];
Also, the logic behind your profiler escapes me a bit. Wouldn't it be sufficient to use something like 'bin[*pc]+=1.0;' on a single 64K array of doubles to gather statistical info about which instructions are called how often?
Another viable method for zeroing in on hot spots is activating the monitor with Alt-M for, say, 50 times. If there is a sub-routine with is called often, its address will show up prominently while the program is interrupted. Only when activity is correlated to the raster lines, this method doesn't work that good, because VICE enters the monitor only when a whole frame has been processed. But in that case, you could use the border colour to signal what routine is currently running - this would also work on a real VIC-20.
@mods: Could this thread, and this one, and this one please be moved into the 'Emulation and Cross Development' section?
Done.
- Kweepa
For the non-pseudocode I'd probably allocate each chunk separately.
The idea is that each chunk represents about a second of run-time. These could then be combined later if you're not interested in the moment to moment timing. So MAX_CHUNKS would not really be constant, but depend on how long you ran the profile.
I have been using the raster timer, but it doesn't work very well for routines that last more than a frame, and it requires a lot of back and forth changing code.
Alt-M*50? I'd rather write the profiler
Agreed.Kweepa wrote:I have been using the raster timer, but it doesn't work very well for routines that last more than a frame,
Why? That's what the preprocessor in C is for. Not only for defining constants - you can also compile code conditionally.and it requires a lot of back and forth changing code.
That might also depend on one's habit how often the object file is (or needs to be) rebuilt.Alt-M*50? I'd rather write the profiler
In MINIPAINT, about the only two routines which are explicitly tuned for speed are the cursor display and the zoom routine, the latter which spends most of its time (~70%) in this tight loop:
.4EF2 A5 A6 LDA $A6
.4EF4 06 A8 ASL $A8
.4EF6 2A ROL A
.4EF7 06 A8 ASL $A8
.4EF9 2A ROL A
.4EFA 06 A7 ASL $A7
.4EFC 2A ROL A
.4EFD 06 A7 ASL $A7
.4EFF 2A ROL A
.4F00 91 FB STA ($FB),Y
.4F02 A5 A5 LDA $A5
.4F04 91 FD STA ($FD),Y
.4F06 C8 INY
.4F07 C0 04 CPY #$04
.4F09 90 E7 BCC $4EF2
Most other routines in MINIPAINT are just written in a way to get the job done.
Full memory - yes (even FE3 superram mode works).Kweepa wrote:I haven't had time to do any work on my profiler. Is vic20emu something I can configure for full memory plus disk drive?
Disc support is also work in progress. You can load the directory ("$"), but the IEC emulation is lacking file load/save support. It is not difficult to implement, but sometimes wrinting or reading the IEC bus fails for reasons unknown to me.
Right you may be!Mike wrote:I do, for sure.Kananga wrote:Do you recognise the code in the debugger window, Mike?
One of my tools includes this code snippet with all files it writes to mass storage.
Actually, I just ran the smurf prg, because it's my favourite.
