Happy New Year!
I have made available a patched version of Frogger '07 with the volume level fix. This version removes the distortion on real VIC-20 computers when two or more audio channels are playing at once.
http://www.mediafire.com/file/c16ky6wk1 ... 7-vol8.zip
Richard
Patched version of Frogger '07 available
- Pedro Lambrini
- rmelick
- Vic 20 Hobbyist
- Website: http://www.geocities.ws/cbm/
- Occupation: IT
sounds great
Sounds great! Thanks!!
The bad news is that I've contacted Victragic in many ways during last year for this fix but he never replied me.... I'm a bit worried
Btw if you agree, I will use this version for next Mega-cart firmware release.
OK, I've just crunched the fixed volume 8 version of Frogger '07 to use it on Mega-Cart, get it here if you prefer the crunched version (click on the small download link on bottom right).
PS: For the crunching work, I've used the latest beta 8 version of exomizer, very big compression and fast decompression, the file is now just 8.983 bytes instead of the original 19.951 bytes
You always need a Vic+16K of course.
Based on my experience, generically yes.tokra wrote:Slightly off-topic:Exomizer? Is it better than pucrunch?
In effect I use a private beta sent to me from the author that fix some problems I've reported him by using the beta7.Where is beta8 to be found? Best I could find was beta7
I think you may ask the author for the new version, he is very kindly.
