A task switcher for the VIC-20 & FE3. Link
(Already announced in the thread "WIP: VIC GUI", but now with more text )
--- README ---
FE3TS allows you to have up to eight virtual environments on your VIC-20 & FE3.
FE3TS-SV is an example for the supervisor written in BASIC that demonstrates
how to use the task switcher.
You can:
* create and reset environments
* switch between them by using the restore key
* save the state of an environment
* load the state of an environment
Everything works fine unless you overwrite the 3K RAM expansion area at $0400-$0FFF.
If the restore handler doesn't work, because the NMI vector was overwritten, just type SYS 1033 to return to the supervisor (environment 0).
Usage:
LOAD"FE3TS.PRG",8,1
NEW
LOAD"FE3TS-SV.PRG",8
RUN
SYS 1024
POKE 780, <nr> : SYS 1027
POKE 780, <nr> : SYS 1030
SYS 1033
POKE 780, <nr> : POKE 781, <file> : SYS 1036
POKE 780, <nr> : POKE 781, <file> : SYS 1039
