Browsing old german '64er' magazines I found this little program called
BASIC PACKER
which not only removes REM and Spaces, but also uses 255 byte in each BASIC-line and uses some other tricks as well (it does 4 passes over each program).
The resulting program is still BASIC but no more editable. The program is for the C64 but I managed to load a VIC-program into the C64 VICE, compact it, and save it again to be reloaded on the VIC. I tried the game-file of "The Great Adventure" and it shortened that one by nearly 3 KB.
I'm sure BASIC-wizards like Jeff might find this useful to squeeze a few more bytes out of programs without having to resort to machine language (which you should learn anyway ).
Shortening BASIC-programs
Re: Shortening BASIC-programs
I have a similar C64 program from Ahoy magazine. It is called, "Compactor". I've even used it with some success on Basic 7/Basic 8 programs for the C128.tokra wrote:BASIC PACKER
Truly,
Robert Bernardo
Fresno Commodore User Group
http://videocam.net.au/fcug
The Other Group of Amigoids
http://www.sccaners.org
- Occupation: farmer
I've used Crunch (which I call Cruncher), and sometimes it's unsuccessful in compressing Basic. That's when I turn to Compactor from Ahoy.GreyGhost wrote:If you guys want a Vic 20 version, look in compute's Gazettes archive for a program called Crunch.
One or the other,
Robert Bernardo
One of my tricks is to simulate a REPEAT loop using FOR NEXTJeff-20 wrote:I feel like I'm pretty good at crunching, but this is really interesting. I wonder if it can intelligently handle GOTOs and GOSUBs. I also use a lot of ON statements.
FORZ=0TO1:GETZ$:Z=LEN(Z):NEXT:REM do more stuff
This trick is maybe a wee bit faster than its GOTO equivalent (for the example shown it is irrelevant, but other purposes may benefit).
The stack will not overflow, the FOR/NEXT is taken from the stack after a key has been pressed. No new FOR/NEXT is built up per iteration.
The trick is actually an example of improper programming: you're not supposed to modify the loop counter other than through the NEXT statement.
How about this variant in WimBasic:
Ceci n'est pas un typo.
10 GETX$:IFX$="".
