They can! I can use 22 double height characters from $1ea0-$1fff and provide another 4 double-height character (=64 byte) actively. I only needed to make sure those 4 characters are updated in time to be displayed, but not so early that they interfere with another area where they are displayed. The upper 8 "T"-characters in area 32-5 were the one to go for, leading to this layout:
AAAAAAAAAAAAAAAABBBBBBBBBB 16-1
CCCCCCCCCCCCCCCCCCCCCCCCCC 32-1
DDDDDDDDDDDDDDDDEEEEEEEEEE 16-2
FFFFFFFFFFFFFFFFFFFFFFFFFF 32-2
GGGGGGGGGGGGGGGGHHHHHHHHHH 16-3
IIIIIIIIIIIIIIIIIIIIIIIIII 32-3
JJJJJJJJJJJJJJJJKKKKKKKKKK 16-4
LLLLLLLLLLLLLLLLLLLLLLLLLL 32-4
MMMMMMMMMMMMMMMMNNNNNNNNNN 16-5
OOOOOOOOOOOOOOOOOOOOOOOOOO 16-6
PPPPPPPPPPPQQQQQQQQQQQTTTT 32-5
RRRRRRRRRRRSSSSSSSSSSSTTTT
UUUUUUUUUUUUUUUUUUUUUUVVVV 16-7
So, I adjusted the 208x272 for myself, shortening the display-clear routine and thinking about a point-plotting routine BASIC. Here's the resulting package:
208272-24k.zip
First, run 208272-24k.prg:
SYS9056: Display graphic, wait for Space-bar
SYS9059: Clear color-ram with actual color
SYS9062: Clear graphic
apfel272m.prg is a good example of all the functions this offers: Line 1-30 are the point-plotting routine, call this by GOSUB 1 with x and y being the coordinates you want to plot a pixel.
apfel1m272 is the standard-fractal picture in multicolor-mode you can load with 2) in the apfel272m.prg
Also included is the source-code of the display-routine for anyone interested.
In conclusion (and I know I've said this before) this is probably the largest true resolution doable on the VIC. I don't think adding another line (like I did in the 208x248 mode) is possible. There still is an area of 160 bytes free in the lower 1K. But another 208x8 line would require a total of 240 bytes (208 for characters, 26(=32) for charmap). I don't think there is enough raster-time or memory left to provide another 80 bytes actively.
What may be possible is a higher color-resolution by using 8x8 chars instead of 8x16 ones. This would however mean that the character-map would be twice as large in memory. Something I will have to think about some more...
