Once the 208x248 resolution was done I realized that this was the best that could be done with the current concept: the raster time was used up nearly completely and the other idea of precalculating the display-routine for each image also fell through because of raster timing. If only I had more raster time, I could increase the resolution... but where to get it?
Then it dawned on me: Operations in the zero-page take one less cycle than to other pages, for example:
lda #$01
sta $1000
uses 2+4=6 cycles. While
lda #$01
sta $00
only uses 2+3=5 cycles. So if I could put as much as possible of the graphics data into the zero page I would save 256 cyles for each full zero page. I realized this would mean a lot more splits, but I started calculating: A double-character line of 208x16 takes up 416 bytes - of which 256 would be in the zero-page and another 160 in page 1. So I would need to overwrite these 416 bytes as often as possible while making sure not to display exactly these bytes while I'm doing the updates. Updating those 416 bytes takes 2240 cycles. Displaying one raster line takes the VIC 71 cycles in PAL. Which means I needed at least 2240/71=31,55 lines in between 208x16 zones to do the updates. This got me excited, since 31,55 is very close to 32 and I can only display multiples of 16 due to the double-character mode anyway. The fit was just too good to be true. I crunched the numbers some more and after some trial and error came up with the following layout:
AAAAAAAAAAAAAAAABBBBBBBBBB 16-1
CCCCCCCCCCCCCCCCCCCCCCCCCC 32-1
DDDDDDDDDDDDDDDDEEEEEEEEEE 16-2
FFFFFFFFFFFFFFFFFFFFFFFFFF 32-2
GGGGGGGGGGGGGGGGHHHHHHHHHH 16-3
IIIIIIIIIIIIIIIIIIIIIIIIII 32-3
JJJJJJJJJJJJJJJJKKKKKKKKKK 16-4
LLLLLLLLLLLLLLLLLLLLLLLLLL 32-4
MMMMMMMMMMMMMMMMNNNNNNNNNN 16-5
OOOOOOOOOOOOOOOOOOOOOOOOOO 16-6
PPPPPPPPPPPQQQQQQQQQQQTTTT 32-5
RRRRRRRRRRRSSSSSSSSSSSTTTT
; Raster-Split-Hires - True 208 * 256 pixels
; only for PAL-VIC 20
; Video-Ram Top: 4096-4511 = 416 double height chars
; Char-Ram Top: 4512-8191 ($11a0-$1e9f) = 3328 Byte
; (208 * 128 res - split to 4x 208*32 res - top area switched around 2 times)
; Low 1k Char-Ram: 0-831 ($0000-$033f) = 832 Byte
; (208 * 32 res - split to 2x 208x16 res - top area switched around 5 times)
; mapped to ($2000-$233f) = (8192-9023) Char 0-51
; 56blanklineswitch -> fill 32-1switch 1/2 - routine: write321
; 208x16 16-1switch -> fill 32-1switch 2/2 - routine: write321
; 208x32 32-1switch -> fill 16-2switch - routine: write162
; 208x16 16-2switch -> fill 32-5switch 1/5 - routine: write3251
; 208x32 32-2 $14e0-$181f -> fill 16-3switch - routine: write163
; 208x16 16-3switch -> fill 32-5switch 2/5 - routine: write3252
; 208x32 32-3 $1820-$1b5f -> fill 16-4switch - routine: write164
; 208x16 16-4switch -> fill 32-5switch 3/5 - routine: write3253
; 208x32 32-4 $1b60-$1e9f -> fill 16-5switch - routine: write165
; 208x16 16-5switch -> fill 32-5switch 4/5 - routine: write3254
; 208x16 16-6 $21a0-$233f -> fill 32-5switch 5/5 - routine: write3255
; 208x32 32-5switch -> fill 16-1switch - routine: write161
; 5 areas of 208x16 (16-1 to 16-5) reside in the zero-page allowing for faster lda #xx sta $yy writes (2240 cycles per area = 256 * 5 + 160 * 6) = 11200 cycles
; 2 areas of 208x32 (32-1 and 32-5) are switched as well = (4992 cycles per area = 832 * 6) = 9984 cycles
; total 21184 cycles leaving 968 cycles.
I realize this post is highly technical, but I wouldn't have been able to come up with it if other technical documentation wasn't posted online as well. Especially Marko Makela's Making stable raster routines has been a big help in understanding how the VIC works, how many cycles a line needs and how many lines a picture has for the VIC. So, if anyone has questions regarding this or - even better - own ideas go ahead and post them, even if you may think they are stupid at first.
Oh, BTW: I have Part 8 already prepared...
