WIP: Vic GUI
WIP: Vic GUI
After finally being able to spend some time on the GUI, I want to share the little progress:
Update of the basic elements demo (former vin-0.2.prg): Demo
(Needs now at least 24K due to the grown framework code&data)
Demo of two new elements, the message box for simple text messages, and a list box: Listbox
(16K)
Besides many little internal improvements, you can grab a window by its title bar and drag it around on the screen.
The framework now includes Mike's font as a third font.
More to come soon...
(16K)
Re: WIP: Vic GUI
Cool!
In 'font4.asm' I found these lines:
That should be 'and #15': even though the majority of the glyphs only use 3 columns, there is one exception: ASCII 126, '~'.
I found one can even drag a window partly off-screen, but only to the right and bottom, not to the left. O.K., that one could make it difficult to close the window, as the close icon disappears.Kananga wrote:Besides many little internal improvements, you can grab a window by its title bar and drag it around on the screen.
f4loop: lda (ch4ptr), y
and #7
f4ptr: sta $FFFF, y
Re: WIP: Vic GUI
Negative coordinates wouldn't work and the close button happens to be in the top left corner, so that fits nicely, eh?Mike wrote:I found one can even drag a window partly off-screen, but only to the right and bottom, not to the left. O.K., that one could make it difficult to close the window, as the close icon disappears.
Changed, thanks!Mike wrote:In 'font4.asm' I found these lines:That should be 'and #15': even though the majority of the glyphs only use 3 columns, there is one exception: ASCII 126, '~'.Code: Select all
f4loop: lda (ch4ptr), y and #7 f4ptr: sta $FFFF, y
Did you notice the mouse cursor acceleration? At first I found it a bit annoying and sometimes it makes it harder to navigate. I had higher values first, but I turned it down to max 3 pixels/move as it is now and it seems a good compromise to me. Should be adjustable for user preferences, of course.
Re: WIP: Vic GUI
Kananga wrote:Changed, thanks!
I got used to it quite fast. The most important aspect being, that you still allow for pixel-exact positioning. And the fast speed is O.K.Did you notice the mouse cursor acceleration? At first I found it a bit annoying and sometimes it makes it harder to navigate.
One strange thing though: as I drag a window around left...right...left, it jumps one character upward every-now-and-then while going left, until it is stopped by the top of screen.
Re: WIP: Vic GUI
Funny that I didn't notice this effect. Thanks for pointing it out. Actually it was quite easy to find&fix: A missing clc (see execfun.asm;r44)Mike wrote:One strange thing though: as I drag a window around left...right...left, it jumps one character upward every-now-and-then while going left, until it is stopped by the top of screen.
Another thing: In one dialog box, you let the user change background and border colour. Default for background is black, with white for foreground. The foreground colour remains fixed, i.e. when you select white as background, you get an all-white screen.
Now, instead of "simply" adding a foreground select as well, you might consider providing either black or white as foreground for the GUI elements, depending which one of these two has the better contrast to the background, like:
If you also make the top 8 colours available as background, maybe Orange should have white as foreground as well, and all others can use a black foreground.
This is the method I use in MINIPAINT to keep the GUI elements visible, regardless which background the user chooses.
background: foreground:
black white
white black
red white
cyan black
purple white
green black
blue white
yellow black
Thanks again for the hint.Mike wrote:Now, instead of "simply" adding a foreground select as well, you might consider providing either black or white as foreground for the GUI elements, depending which one of these two has the better contrast to the background
Actually, I put the color selection dialog into the demo to have something with a visible effect in there. But you are right, a serious configuration should be more sophisticated.
@nbla000: Thanks for the compliments!
- Schema
- factor
After adding file-I/O to the framework and fixing a couple of bugs,
I am proud to present the first almost useful application using the GUI:
diskmenu
Memory requirements are 16K from $2000-$5FFF plus at least the 3K expansion or more.
You can browse through a directory and hit the load button, but ATM it works for directories only.
Unfortunately, the window dimensions do not allow to view more than one drive in parallel.
The program grabs all available RAM, so it may not work with floppy speeders. I plan to take a look at SJLOAD and find out how to make the framework use it.
diskmenu
Just to inform you that I'm working for a NTSC version of SJLOAD to support classic drives (1541/1541-II/1571/1581) with JiffyDOS ROM too.Kananga wrote:I plan to take a look at SJLOAD and find out how to make the framework use it.
At the moment it was successfully tested on 1581+JiffyDOS drive on NTSC machines and it will be tested on 1541 / 1571 drives soon.
If you need further info just send me PM or an email.
I have put together the first release of the GUI prototype. Code size is already becoming a problem, so adding more essential features requires dynamically loading and discarding parts of the program at runtime.
Anyway, the GUI-based file browser is able to browse through SD2IEC drives and launch programs for different memory configurations that can be started with "RUN". It would be great, if you could post feedback about programs that don't load (or work surprisingly good )
Download
From the README:
GUI prototype for the VIC-20 (R1)
This archive contains three programs that demonstrate the features
of the GUI prototype. All programs need a lot of RAM, so they are
best used with Final Expansion or MegaCart.
You can also use an expansion port expander and plug 2x16K and 3K in
to max out the available memory with genuine Commodore hardware.
Minimum requirements are 24K RAM from $2000-$7FFF.
The GUI requires a joystick or (better) a joystick emulating mouse.
You should have a drive with JiffyDOS to minimize load times.
(e.g. sd2iec)
The main application "VIN" scans for available disk drives at addresses
8 to 11 and displays disk icons. Click on an icon to open a file
browser window for the drive. You can now change into and out of
directories (DIR) or disk images (Dnn) and start programs (PRG).
All programs scan present drives for an RTC with valid time on startup.
So better set-up the RTC clock now!
INSTALL:
Copy all files from this archive to a disk or a directory on your SD card.
The files are:
VINBOOT - A boot loader for VIN that first loads SJLOAD into the 3K area ($0400).
VIN - The disk browser.
VINDEMO.PRG - The original demo of basic GUI elements.
VIN20.PRG - Demonstration of the compound elements message box and list box.
SJLOAD$04 - A JiffyDOS floppy speeder (currently maintained by nbla000).
LOADER - A sample loader configuration for the FE3.
Thanks to the community at Denial (http://www.sleepingelephant.com/denial/)
for the initial discussion and encouragement!
2010/09/24 A.M.
Download
From the README:
(e.g. sd2iec)
INSTALL:
The files are:
2010/09/24 A.M.
Thanks. Nothing you wouldn't get from CBM Filebrowser and you can't use the keyboard for navigation. But yes, it's useful after all. Plus you get a watch for free, if you have an RTC as in the FE3.Wilson wrote:Wow, this is great! With the ability to launch programs, I can now see this being legitimately useful. And support for different memory configurations to boot!
Could be a lot given enough time. Any suggestions?Wilson wrote:So, what's next?
