Joystick in user port
vicassembly
Post by vicassembly »
I seem to remember reading that an additional joystick could be added to the user port. Anyone else heard of such a thing? Through an RS232 connection?
Jonathan
Boray
Musical Smurf
Post by Boray »
That is a good idea. Should not be too hard to do.
This exists for the C64:
http://www.protovision-online.de/hardw/build4player.htm
and can be bought ready built:
http://www.vesalia.de/e_c64_4player.htm
On the Protovision site you can also find the source-code how to read the joystick-ports - no idea if this can be adapted to the VIC or if the User-Ports are even identical to support this
There was a joystick adapter released for the Vic20 by OEM, but I can't recall if it split the existing joystick port, or went in the user port.
Ew! Sounds a little perverse. But I'll give it a try. :lol:
Kananga
Post by Kananga »
The Protovision 4-player adapter works for the Vic-20 as well, because it uses the parallel port bits of the user port.
You can either buy or build it yourself, the schematics are available on the protovision site.
I built it some time ago and can now connect three joysticks to my Vic-20. Not that I found any use for it yet...
AFAIK, there was a game published in Compute's Gazette for the VIC which required a second joystick attached to the User port.
Does anybody remember that?
tokra wrote:On the Protovision site you can also find the source-code how to read the joystick-ports - no idea if this can be adapted to the VIC or if the User-Ports are even identical to support this
Modems for the VIC also work on the 64 and vice-versa. There is a certain similitude.
GreyGhost
Post by GreyGhost »
In Compute, March 1983. The game is called Fighter Aces. Also, If you can find a copy of "Tricks for Vics" by Sam D. Roberts, the appendix has an article for adding two additional joysticks to the Vic via the user port.
Rob
nbla000
Salmon Run
Post by nbla000 »
Mayhem wrote:There was a joystick adapter released for the Vic20 by OEM, but I can't recall if it split the existing joystick port, or went in the user port.
It went in the user port and add an just one additional joystick, there are 4 cart games that uses this hardware, Close Encounters, Amazing Maze, Space Ric-o-shay and Tank Wars.
vicassembly
I ordered a copy of Tricks for Vics.... I think I may try it.
rmelick
Website: http://www.geocities.ws/cbm/
Occupation: IT
how to read both ports?
Post by rmelick »
For the Vesalia adapter, anyone know how to read the left port (looking top-down onto the unit)? I can read the right port (closest to the cassette connection looking top-down onto the unit) thusly:
1 DA=37136:POKEDA,0
2 GOSUB10
3 PRINT"{CLR}J0 J1 J2 J3 FB"
4 PRINTJ0;J1;J2;J3;FB
5 GOTO2
10 P=PEEK(DA)
11 J2=-((PAND4)=0)
12 J3=-((PAND8)=0)
13 J0=-((PAND1)=0)
14 J1=-((PAND2)=0)
20 FB=-((PAND16)=0):RETURN
Kananga
Post by Kananga »
The Protovision Adapter multiplexes the input for the ports. So you have to select the port first before reading.
The according bit of the port should be set to output mode (one time initialisation):
POKE DA+2,128
Now select the port for reading:
First port:
POKE DA, 0
Second port:
POKE DA, 128
rmelick
Occupation: IT
thank you
Post by rmelick »
This is great! Thank you!!
e5frog
Website: http://channelf.se
Occupation: Service Engineer
Post by e5frog »
If you only hook up one extra port you don't need any circuitry.
Perhaps a three player worm game would be a doable task on the VIC.
Here are some more examples of games if you haven't seen them already:
http://www.protovision-online.de/hardw/4_player.htm
Here are some code example, for the C64, in assembly:
http://www.protovision-online.de/hardw/ ... htm#codeit
When I wrote my 4 joystick tester program (on the C64) I made it in BASIC and it was a little slow. So perhaps you need to program that part in assembler to speed things up.
rmelick
Occupation: IT
Post by rmelick »
Last night I wrote a special edition of my game with CB2 sound (see Programmer's Reference Guide, pg. 232) and Protovision 4-player interface support. To access these new features, plug your joystick into the outside Protovision port, hold down the fire button and LOAD/RUN the 'Assteroyd Dodger' program.
http://sleepingelephant.com/ipw-web/bul ... php?t=4861
This is the fastest version yet because reading the Protovision joystick requires two fewer steps in the main loop than the default port on the VIC-20. :D
