Best way to create D64 or D71 files on a C128D?
Ok, I've spent two hours browsing the web trying to find the best solution to create D64 or D71 files from my Commodore 128D using an SD2IEC device. I cannot connect the disk drive to the PC since it's integrated into the C128D, and i think there must be way to do it on the C128 with SD2IEC itself. Can anyone help out? The best I found is some tool from 1998, but this doesn't support .D71 as far as I can see:
http://www.kludgesoft.com/c64/d64it.html
Thanks
Torsten
Thanks
Torsten
- plbyrd
- Vic 20 Hobbyist
- Website: http://thesharp.ninja
You may want to check out CBM-Command...nbla000 wrote:It seems that there are a lot of request for a d64/d71/d81 to SD2IEC and viceversa tool maybe with a turbo support too...
http://cbmcommand.codeplex.com
Thanks for the suggestion, but as far as I can see this can only do file-copy - I just want to copy the whole disk track by track, since my discs also have 0 block "------------" files and such.
Unfortunately as suspected D128IT only support 35 tracks (single-sided) discs. Is there no such tool for double sided (70 tracks) 1571-discs or maybe even the 40 tracks single-sided discs?
Torsten
Torsten
- plbyrd
- Vic 20 Hobbyist
No, CBM-Command does both reading and writing of D64 images, you simply need a device large enough to hold them. Take a look at the documentation tab to see the appropriate hot-keys. I would need to see how much work it would be to detect the type of disk in a 1571 to determine whether or not to add D71 support. There is very little memory left for new code in CBM-Command.tokra wrote:Thanks for the suggestion, but as far as I can see this can only do file-copy - I just want to copy the whole disk track by track, since my discs also have 0 block "------------" files and such.
Torsten
I found a solution! Very simple and slow, but it gives exactly the result I was looking for. For future reference: What I had to do was the following:
- create a blank .D71 image in VICE and save that to the SD-card
- mount this image on the C128 so that it is the active "directory"
- copy the whole disc sector by sector from disc to SD
For the last step I found a small program here:
http://www.c64-wiki.de/index.php/Floppy/BASIC_Diskcopy
This is a simple BASIC disccopy-program which was easily extendable to 1571 discs by just amending and adding the first few lines like this:
Basically this just repeats the track/sector table for track 36-70.
This way I can copy my old 1571 double-sided C128 discs to SD It's slow (about 3 hours per disc), but can possibly be speeded up by using the assembler assisted solution and JiffyDOS or possible SJLOAD for C128.
100 data 17,21,24,19,30,18,35,17
101 data 52,21,59,19,65,18,70,17
102 data 0,0
yes it works on VICE too (C64)...tokra wrote:Code: Select all
100 data 17,21,24,19,30,18,35,17 101 data 52,21,59,19,65,18,70,17 102 data 0,0
Do you know which data are required for a 1581 drive ?
According to: http://www.c64-wiki.com/index.php/VIC-1581 the 1581 has 80 tracks with 40 sectors each, so it *SHOULD* just be:nbla000 wrote:Do you know which data are required for a 1581 drive ?
100 data 80,40,0,0
Torsten
Thanks, I will try.tokra wrote:so it *SHOULD* just be:Code: Select all
100 data 80,40,0,0
I should have it in some place btw it was a Program for Vic+8k+3K based from the C64-wiki to write from a 1541 to a d41 file image.Do you remember where to find that program from Diddl?
It should be here on Denial in some place btw do you want I search it on my archives ?
Found it: http://sleepingelephant.com/ipw-web/bul ... 4&start=15
It's the same program that's linked on the C64-Wiki which I used.
Yes It's the same program just adapted for the Vic and to write to a d64 file image instead to real disk.
I'm playing with it a bit and at the moment I'm able to do these tasks (in emulation):
1541 to 1541
1541 to D64
1571 to 1571
1571 to D71
1581 to 1581
D64 to 1541
D71 to 1571
I can do these tasks too (but not in emulation of course):
1581 to D81
D81 to 1581
All for Vic+8K+3K (or Mega-Cart) it works but it is very slow.
Now I've a program for each task next step is to join all programs.
1541 to 1541
1541 to D64
1571 to 1571
1571 to D71
1581 to 1581
D64 to 1541
D71 to 1571
1581 to D81
D81 to 1581
Good idea! You could also make it totally universal, by impementing a check for which system it's being run on (VIC-20, C64, C128). The assembler code uses kernal-routines from the jump-table which should be the same for all three. Also there are no jmp in the routine itself, so it's relocatable. For a VIC it can be stored at $0400 or $a000, for a C64 at $c000 and for a C128 at $1300. Would be nice and small allround-tool this way
