fcbpaint-0.5 (168*192, 8x4 char, inline splits)
Author: tlr
Release Date: 2010-05-21
Requirements: VIC-20 (PAL) with 32Kb expansion.
Download: fcbpaint-0.5.zip
Description:
This is a preview of an editor for a new graphics mode I've been working on for a while.
The mode has 168*192 pixels with 8x4 char color and inline color splits.
The editor and viewer is a little rough around the edges but fully usable.
currently PAL only.
Basic format:
- bitmapped mode
- 21 * 48 "chars"
- each char is 8*4 pixels (hires) or 4*4 pixels (multicolor)
- each line (pixel row) has an initial border, background and auxcolor. (aux = $900E, border+bg = $900F).
- each line can split $900E and/or $900F in-line.
Splits:
- one register can change at a time. (eg, border+bg _or_ aux)
- splits always start at a point and continue until the next split to the right or until the end of the line.
- splits can start on any half char boundary (but will happen one hires pixel late)
- splits are compiled to machine code upon entering the viewer.
- the only way to guarantee that a particular combination of splits is allowed is to enter the viewer and check.
- there are some rules that can be followed to make success likely:
-- splits are always allowed 3 chars appart.
-- in some cases splits as close as 2 or 2.5 chars appart are allowed.
See the included README.txt for details.
Editor screenshot:
Author: tlr
Description:
currently PAL only.
Basic format:
- bitmapped mode
- 21 * 48 "chars"
Splits:
Editor screenshot:
Re: fcbpaint-0.5 (168*192, 8x4 char, inline splits)
Wow! That is some nifty graphics-mode. Let me see if I understand how it works:
- you DON'T use double height chars (8x16), but the standard chars (8x8) instead.
- character-RAM is at $1000-$1fff
- video-RAM is at $0000 AND $0200 using the same 504 chars twice
- and so color RAM is at $9400 and $9600
- every 4 raster lines you switch the video-RAM (color-RAM switches automatically) as such providing a higher color-resolution (8x4 instead of 8x8)
- background, border ($900f) and multicolor ($900e) are switched at least on EACH raster-line, more often as raster time allows
Am I correct?
Especially the last feature impresses me. How do you manage to time the splits inside a raster-line so flexbile that the user can more or less decide where the color changes?
Oh, and are the demo-pics somewhere that demonstrate the power of this graphics-mode?
Am I correct?
Yes.tokra wrote:Wow! That is some nifty graphics-mode. Let me see if I understand how it works:
Am I correct?
This is the complex part. It's not yet fully bug free but works surprisingly well.tokra wrote:Especially the last feature impresses me. How do you manage to time the splits inside a raster-line so flexbile that the user can more or less decide where the color changes?
The splits are contained in tables at $6600, one for each raster line every 32 bytes.
format:
VVVVVVVV, WWWWWWWW (V=<val0E>, W=<val0F>)
PPPPPPPR, VVVVVVVV (P=Position, R=Register, V=Value)
00000000
Basically I reserve the Y register to do screen/color/char mem switching.
A and X are free to use.
For each line it will generate code like:
LDX #$3C ;2
LDA #$1B ;2
STA $900F ;4
STX $900F ;4
STA $900F ;4
LDA $3E ;3 <-- trick $00-$ff contains sequential values (LDA $3E <-> LDA #$3E)
STA $900F ;4
NOP ;2
NOP ;2
BIT $EA ;3
Not yet but I'd love people to make some pics using it!tokra wrote:Oh, and are the demo-pics somewhere that demonstrate the power of this graphics-mode?
I'm not much of a graphician myself.
This makes me wonder what other gems are hidden on other people's HDs.tlr wrote:HISTORY
fcbpaint V0.5, 2009-11-19
Since the graphics mode used by fcbpaint is a true superset of the one used in MINIPAINT, a converter could serve as useful start point:tlr wrote:Not yet but I'd love people to make some pics using it!
10 REM ** MG2FCB V2
11 :
12 INPUT"MG FILE";S$:INPUT"FCB FILE";T$:DN=PEEK(186):@LOAD(S$),DN:B=PEEK(36879)
13 OPEN2,DN,1,T$:PRINT#2,CHR$(0)CHR$(81)CHR$(70)CHR$(67)CHR$(66)CHR$(0);
14 PRINT#2,CHR$(BAND7)CHR$(BAND7);:FORT=1TO250:PRINT#2,CHR$(0);:NEXT
15 FORY=0TO11:GOSUB21:NEXT:FORT=1TO32:PRINT#2,CHR$(0);:NEXT
16 FORY=12TO23:GOSUB21:NEXT:FORT=1TO32:PRINT#2,CHR$(0);:NEXT
17 GOSUB25:GOSUB25
18 A=PEEK(36878)AND240:FORY=1TO192:PRINT#2,CHR$(A)CHR$(B);
19 FORT=1TO30:PRINT#2,CHR$(0);:NEXT:NEXT:CLOSE2:@RETURN:END
20 :
21 FORX=0TO19:AD=4352+192*X+8*Y
22 FORT=0TO7:PRINT#2,CHR$(PEEK(AD+T));:NEXT
23 NEXT:FORT=0TO7:PRINT#2,CHR$(85);:NEXT:RETURN
24 :
25 FORY=0TO23:AD=37888+20*INT(Y/2)
26 FORX=0TO19:PRINT#2,CHR$(PEEK(AD+X)AND15);:NEXT:PRINT#2,CHR$(8);:NEXT
27 FORT=1TO8:PRINT#2,CHR$(0);:NEXT:RETURN
28 :
29 REM ** MG2FCB V2 WRITTEN 2019-03-02 BY MICHAEL KIRCHER
As an example, I've converted the Smurf image I recently did in MINIPAINT, and loaded it into fcbpaint:
Edit: repaired defunct links (again)
Edit 2 (2019-03-02): decommissioned original version of MG2FCB. Link updated, please reload and use only new V2 version!
Very useful, nicely done!Mike wrote: Since the graphics mode used by fcbpaint is a true superset of the one used in MINIPAINT, a converter could serve as useful start point:
After toying around with fcbpaint a little bit, I found some of those edges, which could be rounded off:
- I'd like a directory display, preferably accessible from the main menu. Running it on VICE I often caught myself using the preview of 'Attach disc image ...', but of course that wouldn't be available on a real VIC-20,
- Starting out from an empty canvas, it would be nice to be able to preset background, border, and auxiliary colour globally; so it isn't necessary to change them on every raster instead,
- In a related matter, being able to copy&paste the splits of a raster line would save a lot of time. In the mock-up screen of LeMans I had to re-do 3 splits, and 4 colour settings on all 192 rasters ...
- More a matter of ergonomy: the hectic cursor blinking is just short of annoying. It would be better if it only blinked at, say, the same rate as the normal text cursor.
- Finally, a quick key reference accessible with a hot key would a very useful addition. I found myself having a text window open to the right of the VICE window just for that reason.
True. Shouldn't be too hard.Mike wrote:After toying around with fcbpaint a little bit, I found some of those edges, which could be rounded off:
Good suggestions, will consider those!- In a related matter, being able to copy&paste the splits of a raster line would save a lot of time. In the mock-up screen of LeMans I had to re-do 3 splits, and 4 colour settings on all 192 rasters ...
This is already possible but undocumented.Mike wrote:- Starting out from an empty canvas, it would be nice to be able to preset background, border, and auxiliary colour globally; so it isn't necessary to change them on every raster instead,
If you change colors in the editor, then exit to the menu and initialize the picture it should use the current colors.
Exin has drawn a great picture (a Fire Pokemon?) with fcbpaint.
He noted, that a stand-alone viewer is still missing. Maybe, as alternative, a PC hosted converter could compile the fcb picture into a executable?
A bump also with a question whether there has been some progress with the editor in the meanwhile.
