I had a think about this, and came up with some code that does a BSOD-like display when the CPU hits a BRK instruction - the idea is that you set the BRK vector at $0316/17 to point to the BSOD routine, which makes debugging fairly easy as you can just drop a BRK into your code where-ever you want to 'panic'.
Here's BSOD, which weighs-in at a chunky 479 bytes, but is giving you a 'pretty' display:
; BSOD
; Displays a Blue Screen of Death with register information when BRK encountered.
; Note: set BRK vector at $0316-0317 to point to this routine
bsod SUBROUTINE
sei ; Disable interrupts
pla ; Pull .Y from stack
sta P0FREE ; Save to zero-page
jsr dec2hex ; Convert to hex
lda P0FREE+1 ; Copy to contents line
sta .bsodm6y
lda P0FREE+2
sta .bsodm6y+1
pla ; Pull .X from stack
sta .bsodm6x
lda P0FREE+2
sta .bsodm6x+1
pla ; Pull .A from stack
sta .bsodm6a
lda P0FREE+2
sta .bsodm6a+1
pla ; Pull .SR from stack (BRK)
; Cycle the .SR bits out for the flags line
lda #"1" ; Bit-set indicator
ldx #14 ; Flag character index in .X
.cycle ror P0FREE ; Sets/clears Carry to bit value
bcc .nextbit ; Carry clear, so skip to next bit
sta .bsodm8n,x ; Set bit indicator
.nextbit dex ; Decrement flag character index
dex
bpl .cycle ; Loop for next bit if not all done
ror P0FREE ; Final rotate to return to start value
sta .bsodm6sr
lda P0FREE+2
sta .bsodm6sr+1
pla ; Pull .PCL from stack (BRK)
sec ; Set Carry
sbc #2 ; Compensate PCL for BRK
bvc .pchok ; Overflow is clear when result >=0
; If PCL underflowed when we subtracted 2, adjust PCH down as well
pla ; Pull .PCH from stack (BRK)
sec ; Set Carry
sbc #1 ; Subtraction because PCL underflowed
pha ; Push it back to stack
.pchok jsr dec2hex ; Convert to hex
sta .bsodm6pc+2
lda P0FREE+2
sta .bsodm6pc+3
sta .bsodm6pc
lda P0FREE+2
sta .bsodm6pc+1
tsx ; Move .SP to .X
stx P0FREE ; Save to zero-page
sta .bsodm6sp
lda P0FREE+2
sta .bsodm6sp+1
jsr CINT1 ; Reset VIC
lda #110 ; Blue screen
sta SCRNCOL
lda #1 ; White text
sta CURRCOL
jsr CLRSCRN ; Clear the screen
dcprint bsodm1 ; Error title
dcprint bsodm5 ; Hyphens
jsr GONXTLN ; Skip a line
dcprint bsodm2 ; Data title
dcprint bsodm3 ; Register headings
dcprint bsodm6 ; Register contents
dcprint bsodm7 ; Flags title
dcprint bsodm8 ; Flag bits
dcprint bsodm4 ; End of Line gag
;DC.B $02 ; HLT - stop CPU (UNDOCUMENTED OPCODE - not in DASM lexicon)
jmp * ; Endless loop - use if you don't want HLT
; Information message strings
bsodm1 DC.B " * APPLICATION BREAK *"
DC.B 0
bsodm2 DC.B " TECHNICAL INFORMATION"
DC.B 0
bsodm3 DC.B " PC AC XR YR SP SR"
DC.B 13,13,10,0
bsodm4 DC.B " *** END OF LINE ***"
DC.B 13,10,0
bsodm5 DC.B " ---------------------"
DC.B 13,10,0
bsodm6 DC.B " "
.bsodm6pc DS.B 4,"0000"
DC.B " "
.bsodm6a DS.B 2,"00"
DC.B " "
.bsodm6x DS.B 2,"00"
DC.B " "
.bsodm6y DS.B 2,"00"
DC.B " "
.bsodm6sp DS.B 2,"00"
DC.B " "
.bsodm6sr DS.B 2,"00"
DC.B 13,10,0
bsodm7 DC.B " SR : N V - B D I Z C"
DC.B 13,10,0
bsodm8 DC.B " "
.bsodm8n DS.B 1,"0"
DC.B " "
.bsodm8v DS.B 1,"0"
DC.B " "
.bsodm8u DS.B 1,"0"
DC.B " "
.bsodm8b DS.B 1,"0"
DC.B " "
.bsodm8d DS.B 1,"0"
DC.B " "
.bsodm8i DS.B 1,"0"
DC.B " "
.bsodm8z DS.B 1,"0"
DC.B " "
.bsodm8c DS.B 1,"0"
DC.B 13,10,0
And here's BSODLITE, which does much the same but with less prettiness, and at only 300 bytes:
; BSODLITE
; Displays a mini-Blue Screen of Death with register information when BRK encountered.
bsodlite SUBROUTINE
sta .bsodm6y
lda P0FREE+2
sta .bsodm6y+1
sta .bsodm6x
lda P0FREE+2
sta .bsodm6x+1
sta .bsodm6a
lda P0FREE+2
sta .bsodm6a+1
ldx #7 ; Flag character index in .X
sta .bsodm6sr
lda P0FREE+2
sta .bsodm6sr+1
sec ; Set Carry
sec ; Set Carry
sta .bsodm6pc+2
lda P0FREE+2
sta .bsodm6pc+3
sta .bsodm6pc
lda P0FREE+2
sta .bsodm6pc+1
sta .bsodm6sp
lda P0FREE+2
sta .bsodm6sp+1
sta SCRNCOL
lda #1 ; White text
sta CURRCOL
DC.B 13,10,0
bsodm6
DC.B " "
DC.B " "
DC.B " "
DC.B " "
DC.B " "
DC.B 13,10,0
bsodm7 DC.B " SR: NV-BDIZC"
DC.B 13,10,0
bsodm8 DC.B " "
.bsodm8n DS.B 1,"0"
.bsodm8v DS.B 1,"0"
.bsodm8u DS.B 1,"0"
.bsodm8b DS.B 1,"0"
.bsodm8d DS.B 1,"0"
.bsodm8i DS.B 1,"0"
.bsodm8z DS.B 1,"0"
.bsodm8c DS.B 1,"0"
DC.B 0
You'll need to have the DEC2HEX subroutine and the DCPRINT macro available as well:
; DEC2HEX
; Convert 8-bit binary in $fb to two hex characters in $fc and $fd
dec2hex SUBROUTINE
lax P0FREE ; Get the original byte into .A and .X (UNDOCUMENTED OPCODE)
and #$0f ; Mask-off upper nybble
tay ; Stash index in .Y
lda .chars,y ; Get character
sta P0FREE+2 ; Save it in the hex string
txa ; Get the original byte again
lsr ; Shift right one bit
sta P0FREE+1 ; Save it in the hex string
rts
; Conversion table
.chars DC.B "0123456789ABCDEF"
; DCPRINT address
; Created by Valarian
; Call the VIC-20 ROM 'PRINT' routine.
; Parameters are:
; address - start address of zero-terminated string to print
MAC DCPRINT
lda #<{1} ; .A contains MSB of message start address
ldy #>{1} ; .Y contains LSB of message start address
jsr STROUT ; Call ROM routine
ENDM
Making it work is just a matter of:
lda #<bsod
sta BRKVEC
lda #>bsod
sta BRKVEC+1
brk
Oh, you'll need my VICMAP file as well for the memory-map label definitions:
http://vicdev.googlecode.com/files/VICMap.6502
