WIP - Yet another Character Set Editor
This is my 2nd project for the VIC "CharEdit" - Current target VIC 8k+ RAM.
You may wonder why do another one as there have been lots of these down the years.
Well the reasons are twofold :-
1) Being quite a common utility that we have all used at one time or another, makes it an easier task for me to implement - and therefore further my knowledge of the VIC / 6502
2) If you read the list of planned features below, I'm attempting to implement some features that I have not come across in other editors I have tried - that I would personally find useful, and hopefully you too.
Current Planned Features
All 256 chars available for editing in 2 x 128 banks one keypress to toggle banks (Due to screen space).
Editor Features - Rotate / Invert / Flip / 4 way scroll with wraparound / single row + column scroll / Cut / Copy / Paste / Undo / Pixel Toggle / Hex + Decimal data display.
File I/O Features - Load from 1 to 256 chars to any point in the character set / Save from 1 to 256 chars from any point in the character set with user definable load address / Export from 1 to 256 chars to BASIC (PRG) - Assembler Source (ASM) - Binary (BIN).
Notes
PRG starts off in select mode - use cursor keys to select a character / "B" to toggle bank 1 + 2 (0-127 + 128 - 255) / "E" go to Edit Mode / "S" save / "L" load <--- Note Save/Load quite pointless ATM due to Edit mode not finished.
Edit Mode Keys
R - Rotate
F - Flip
I - Inverse
C - Cut
1 - Scroll Up
2 - Scroll Down
3 - Scroll Left
4 - Scroll Right
All other features are not yet implemented, like pixel toggle / Return to select mode
Expect much more functional version in the next few days.
Also apologies for any quirky key layouts - Using Vice not a real VIC - so keyboard layout it slightly different.
Always Link to Latest Version
Notes
Edit Mode Keys
R - Rotate
F - Flip
I - Inverse
C - Cut
1 - Scroll Up
2 - Scroll Down
3 - Scroll Left
4 - Scroll Right
Thanks for your comments SchlowskiSchlowski wrote:Looking very nice, I like the idea to use a non-standard font for the program.
Missing a horizontal flip (<|>) additionally to the vertical flip.
I'm looking forward to see your next versions, keep up the good work!
The font is one of Jeff's that he made available recently - thanks Jeff
Horizonal flip can be achieved - with Flip and Rotate x 2, so I haven't implemented a single keypress version ATM (lazy).
I Should have another version out soon with all the editing features completed, as well as bog standard Load / Save of the whole 256 chars with user entered filename.
This then leaves the advanced Load/Save and Export stuff to do which is a challenge in itself considering my current novice VIC status
After that some colour injection/cosmetic tweaks to finish off.
These templates might be of interest to you:KingTrode wrote:This then leaves the advanced Load/Save and Export stuff to do [...]
http://www.sleepingelephant.com/ipw-web ... 01&start=5
If you want to save a memory range with another load address than where it's stored, you'll need to use OPEN, CHKOUT, CHROUT, and CLOSE. And this method then only works with disk drives. It is cheaper just to force a load to another address, with the programm that actually uses the charset binary.
And horizontal mirroring should be easy enough with $xx being a free ZP address:
; ** mirror A
LDX #8
.loop
LSR A
ROL $xx
DEX
BNE loop
LDA $xx
Link in first post to latest version.
Update:
Full edit cursor movement
"Space" to toggle pixel on/off
"E" to leave edit mode and make permanent any changes made to character.
Load / Save Static filename "CHR.CHAREDIT" - all 256 chars - no error handling ATM
See previous posts for earlier features / keystrokes.
Next update to contain:
"Q" to leave edit mode and cancel and changes made to character.
Copy / Paste / undo in edit mode.
File name input for load/save.
Update:
I've noticed the following issue: as edit mode is left, the "window" for the character select cursor is kept in the state for the edit mode. For this reason, it is now even possible with the select cursor to roam outside the visible screen."E" to leave edit mode and make permanent any changes made to character.
It looks like you constrain the cursor similar to this pseudo-code:
IF <left> AND X<>0 THEN X=X-1
IF <right> AND X<>7 THEN X=X+1
etc.
Found some time to play around with your editor, works like a charm.
I like your screen layout, very clear and easy for the eyes, not as crowded as my LCE.
But may I request a little feature: As I'm growing older and my memory does not serve me as it did 30 years before I tend to forget which keys/commands are available. A little help screen when pressing F1 for example would be great. You should have enough memory for that, I hadn't when I wrote LCE so I put every info into the main editing screen.
Good work, I'll keep an eye on your progress!
Thanks for the feedback SchlowskiSchlowski wrote:Found some time to play around with your editor, works like a charm.
I will be putting in a Help key feature that shows all keystrokes for both modes, I forget them myself too and I wrote the sucker - Old Age on my part I guess - lol
Should be in there soon, as I have pretty much done with implementing all the features, though the advanced File I/O features are far from finished yet.
Another release is due tonight/tomorrow, the one after that should have a help screen in there as well as a bit of colour here and there.
A very valid point. And it is not only justified because of Old Age - other programs will use another keyboard command set. Unless you often use a certain program you'll at least confuse keys.Schlowski wrote:which keys/commands are available. A little help screen when pressing F1 for example would be great. You should have enough memory for that
A program can be rendered unusable over the years, if its off-line documentation is lost. There are enough similar programs available on Zimmers, you start them, they present their screen mask, and your next question then is: "What now?"
So true Mike, I have had that problem myself with PRG's I have downloaded and then scratched around hoping to find some kind of documentation and drawn a blank.
This can be quite frustrating, and to avoid putting users through the same thing when using my software - I shall always make sure it's in there for them.
