Light Pen software
vicassembly
Light Pen software
Post by vicassembly »
I am looking for light pen software for the vic-20 or the C-64. I purchased something on eBay and the box came with a light pen but WITHOUT the software disk. :evil:
I am looking for graphics software or anything that you might suggest.
Jonathan
vic user
VicGyver
Post by vic user »
I have a light pen, manual, and also the software that came with it.
I will try and make a copy of the material for you.
Chris
vicassembly
Many thanks, Chris!
vic user wrote:I have a light pen, manual, and also the software that came with it.
Chris
saehn
Re: Light Pen software
Post by saehn »
vicassembly wrote:I am looking for light pen software for the vic-20 or the C-64. I purchased something on eBay and the box came with a light pen but WITHOUT the software disk. :evil:
Jonathan
Wait, I'm not sure that all light pens are created equal. Which light pen do you have, does it have any make or model number?
vicassembly
This is a Tech Sketch light pen. (Ampower Technologies)
saehn
Post by saehn »
I could only find this, and I'm not sure but I think it may have been altered to work with joystick only. It's worth a shot:
http://www.planetemu.net/index.php?sect ... &id=660230
The Tech-Sketch light pen worked with (and was often packaged with) a paint program called MicroIllustrator. I had this package as a child.
Frankly, though: the KoalaPad is much better than any light pen, with Suncom's Animation Station being a close second. Also, coincidentally, I have one up for auction right now. :-D
vic user
VicGyver
Post by vic user »
Yes, the koalapad rocks!
I have the cardco light pen.
Once I copy the manual and software, I hope the material is useful.
