Hacking Vic-20 cartridges
Hi, I was wondering which (if any) common vic-20 carts may
have EPROMs in them, instead of roms. A socket would be
even better.
On the 64 side, I have found that the Mach 5 disk utility
cart is nice. It has an 8k socketed EPROM that is easily removed,
reprogrammed and re-installed. Or, even better, replaced with
a 64k (or larger) EPROM and a selector switch.
I would like to try this with the vic. If anyone has any info
about this, please let me know!
Thanks,
Brian
even better.
Thanks,
Brian
- Schema
- factor
As it happens, 6502dude is (hopefully) going to be showing us how to do this at the next TPUG meeting here in Toronto.
For the C64, you don't have to butcher old cartridges - Alphaworks sells new, blank cartridge PCB's. http://www.alphaworks.com.au/store.htm
It would be great if there was an equivalent for the VIC-20!
Some of the Vic-20 cartidges simply have a chip (blob) stuck to circuit board. Others have 24 DIP ROM chip.
Cartridges are pretty cheap, so it is simple to desolder DIP version of rom chip, insert a socket and you are ready for eprom insertion.
The ROM pinout is same as 2532 (4K) eprom. Cutting a couple of traces and wiring allows use of more standard 2732 Eproms.
One challenge is finding modern eprom burners that will work with eproms this small.
If you don't wish to hack up a Vic-20 cartridge, Rat Shack used to sell 44 pin edge card circuit boards that matched Vic-20 interface port. I think they may be discontinued now though. I have wired up one of these for use with 2764 (8K eproms) with such a board.
Before anyone yells at me, no Vic-20 carts were harmed to
research this post tonight!
I found that my Submarine Commander (Thorn EMI) and
VIC Forth (HES) both have EPROMS inside, but are not socketed.
As for a modern eprom burner, I use this:
http://www.ustr.net/epromer5/index.shtml
I really like it. Works well with the older, smaller eproms I need
to use.
to use.
I haven't seen a cartridge yet that has uses sockets for Roms.
Sockets + ROM or Eprom + cartridge cover presents a bit of a physical clearance problem (it will not fit into Vic-20).
This is another reason to leave top cover off your hacked Vic-20 cartridge.
Plus, for manufacturers, using sockets just adds to production costs and would have provided hackers back then an easier option to pirate games.
I use Promenade for smaller Eproms. It will burn up to 27512 (64K). I once used it to burn a 27010 (128K) with socket adapter, but this was a bit of a PITA.
I have built a could of Eprom burners so I can do eproms from 2764 (8K) though to 29040 (512K flash eeproms), at much faster rate than Promenade.
Well, the casing doesn't have to be a flat box, it could be in two terraces of which the chip is mounted on the back end, something like this:
___
_____/ |
_|_________|
carlsson wrote:Well, the casing doesn't have to be a flat box, it could be in two terraces of which the chip is mounted on the back end, something like this:
___ _____/ | _|_________|
Nice pic!!!
The height issue is with modification of exiting cart. ROM chip on cartridges tend to near center of premade cartridges. Using 22 (A/B) edgecard project perfboard allows alot more flexibility where you locate eprom for CRT ROM image hacking.
Ah, so the idea would be to solder away the ROM chip and put a socket plus something into it. Yes, in that case I can agree if it gets tight, although the circuit design may differ a little on different cartridges (and you want one which has all or as many pins as possible connected).
Here are some pictures on Vic-20 cartridge hacking
(a) Bottom of case - note location of screw and 2 slots at top of image which have clips to release top & bottom of case
http://www.bjlyons.com/cbm/vic-20/4kbotcase.jpg
(b) Bottom of circuit board - 2 traces cut and 2 wires added to modify for use with 2732 Eproms (I'll bet somebody can tell what was orginally in this case based on number sticker on board)
http://www.bjlyons.com/cbm/vic-20/4kbotcct.jpg
(c) Case with circuit board. I orginally used 2532 then modified and made note on case. Note socket installed in place where ROM was.
http://www.bjlyons.com/cbm/vic-20/4ktopsocket.jpg
(d) As above in (c) but with 2732 Eprom installed in socket
http://www.bjlyons.com/cbm/vic-20/4ktopeprom.jpg
(e) 8K board I quickly put together a long while ago to test 8K ROM images. No special address decoding. I may change to 27256, add some address code logic and add real time clock chip (just need the spare time)
http://www.bjlyons.com/cbm/vic-20/8ktop.jpg
(f) As above in (e) bottom of circuit board
http://www.bjlyons.com/cbm/vic-20/8kbotcct.jpg
Cheers!
Cheers!
- Schema
- factor
Excellent, thanks again.6502dude wrote:Here are some pictures on Vic-20 cartridge hacking
I made the same changes to one of my carts (Mole attack, I have several copies) and added a socket, and it works perfectly! The Hesmon ROM you gave me works fine.
Where does the 4K on the ROM show up in the VIC's memory again?
If it autostarts: $a000-$afff.Schema wrote:Where does the 4K on the ROM show up in the VIC's memory again?
The same data could show up as mirror images in other places aswell (like $b000-$bfff), but $a000-$afff is the primary place.
The kernal reset routine at $fd22 will to an indirect jump to ($a000) when a rom is identified.
