Can you use a 6502B clocked at 1Mhz in a Vic20?
Just looking for a new 6502 but arcadecomponents.com doesn't have any only B's.
- Vic 20 Hobbyist
Re: Can you use a 6502B clocked at 1Mhz in a Vic20?
I have some As but haven't put them on the site yet. The B is just a faster rated CPU that can run at a higher clock speed. It will run fine in the VIC 20.
RJ
RJ
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
- Occupation: Computer Technician
So, Let me get this straight... You are saying that the The 6502B chip variant commonly found in 1541 drives will drop right in and work fine in a VIC-20?? I have always wondered this.... :0) Tony K. Has anyone here actually ever tried this???
As the two posters from 2010 are somewhat unlikely to respond, here's the relevant part of my VC-20's mainboard:
Any questions?
Any questions?
Its just the maximum clock rating, many MOS chips have this. In a VIC20 (or C64 for that matter) any "A" or "B" (and variants without) can be used
