Nils from "For8Bits" is developing a new hardware for 6502 systems/computers.
It is very similar to Final Expansion for VIC-20, but it is much more universal useable. David-65 works on every 6502 board: PET, CBM, VIC-20, any Commodore Floppy ...
Simply do following to install David-65:
* remove 6502 CPU (hope it has a socket)
* insert David-65 into CPU socket
* insert CPU into David-65 board
David-65 offers nearly same features than a FE2:
- CPLD for programmable memory configuration
- additionally 512 Kb SRAM
- additionally 512 Kb Flash (programmable)
- a RS-232, very slow - only for debugging (software driven like in a C-64)
- a LED for diagnostic purposes
- extension of a PET / CBM / VIC
Any PET or CBM with 8KB or 16KB will have 32KB also
If RAM or ROM (or both) is damaged David-65 will replace it without soldering
You can choose between any BASIC, any Kernal and any Software extension (ExBasic, Assembler, ...). You can switch between different editor ROM and different languages. And of course any RAM configuration, also for address ranges where is normally ROM (kernel, Basic, ...).
New Software can use whole 1MB of the David-65 memory - Diagnostic
David-65 can start with own Flash and own RAM, so nearly no "external" hardware is nessecary. Only power and clock for the CPU is nessecary to run diagnostic.
A badly hard damaged 6502 system could be analysed from CPU's sight. Even if Kernel or Zeropage is damaged, David-65 will find it out. - Ultimative Speeder for a 1541 drive (200 times!)
My personal favourite goal is the ultimate speeder for a floppy drive (1541, 1571). David-65 can hold two full D64 Images or one D71 image. Installed in a 1541 floppy David-65 can read whole disk into memory and so access data in RAM disk like speed. Write access goes into RAM and will be written in idle time (lazy write back). - David-65 can act as a standalone 6502 board if a 5V power and a clock is available ...
