Hi
I have just tried to use an older style VIC-20 after a few years of relative inaction. When first plugged in, I got a standard screen border but no text. Next, this reverted to a partial screen checkerboard of random characters and some random noise. Now no picture at all - just a back screen.
My immediate reaction, since both screen and (initially) sound went wrong was the VIC. Has anyone seen something similar and/or do you have any better ideas of the problem? Appreciate any help I can get.
I plan to hunt around for another 6561 anyway...
Dead VIC chip?
I thought about the PSU. It is the older two prong type. These are meant to be 9V AC. I checked the one I have and it is reading a solid 10.6V AC on a multimeter. I thought less than 12V AC would be fine. Is this likely to be the cause?Vic20-Ian wrote:Doesn't sound good. Sounds like character rom first then maybe the Vic to me.
I would get the PSU checked out before plugging it into another Vic20.
I think I secretly hoped it wasn't a RAM problem but a socketed chip. Finding a known working PAL VIC will probably take a while to eliminate that potential problem.Barney wrote:Same thing happened to me. I thought it was the Character rom but that wasn't it. Sombody else on Denial diagnosed it as a possible RAM problem. One of the ram chips is likely bad and needs to be replaced. Good luck.
Barney
There seem to be some places on line that have them, such as the following:
http://www.arcadecomponents.com/customroms.html
I thought $4.99 was pretty reasonable.
The real tell-tale was how hot the ROM became - very hot after 5 minutes. That wasn't enough, though. It was actually hotter than the VIC chip (a pretty big effort for a ROM). Funnily enough, I had checked the temp on all the other chips (besides the ROMs) previously, so I never spotted it.
