Stupid BASIC Noob Question Time
Pedro Lambrini
Post by Pedro Lambrini »
Okay, I haven't written any code in about 20 years so bear with me! I want to write something where the user can only choose one of two options. I have typed in this:
10 input"1 or 2";a
20 if a=1 then gosub 200
30 if a=2 then gosub 210
40 print"well done!"
50 goto 10
200 print"you chose left"
205 return
210 print"you chose right"
215 return
It seems to work but if I type anything other than "1" or "2" nothing really significant happens and the code carries on running. How would I write the code so that only one of the two options are acceptable? I know that with numbers I could use the < > signs to stop numerical values but what about letters or PETSCII??
I hope what I'm asking is clear!! Thanks in advance. :)
You can separate the whole input routine into an own sub-routine. And, in that case, use GET instead of INPUT. Then the code could look like this:
10 GOSUB 100
20 IFA$="1"THENPRINT"YOU CHOSE LEFT"
30 IFA$="2"THENPRINT"YOU CHOSE RIGHT"
40 PRINT"WELL DONE!"
50 GOTO 10
100 PRINT "1 OR 2?"
110 GETA$:IFA$="1"ORA$="2"THENRETURN
120 GOTO 110
Effectively, the GOSUB 100 only returns, when an acceptable key has been pressed. Otherwise, the sub-routine will remain in its loop.
You can change the acceptable keys within the IF statement in line 110, and alter the PRINT statement the reflect the change.
The PRINT statements in the lines 20, and 30 of course only serve illustrational value, you must decide what actions should be taken, and these, again could be delegated to sub-routines again.
Pedro Lambrini
Thanks very much. I'll play around with this for a wee while. :)
Leeeeee
soldering master
Post by Leeeeee »
Or, just to confuse you further..
10 INPUT "1 OR 2"; A
20 IF A=1 THEN GOTO 200
30 IF A=2 THEN GOTO 210
40 PRINT "YOU CHOSE NEITHER LEFT NOR RIGHT!"
50 GOTO 10
60 PRINT "WELL DONE!"
70 GOTO 10
200 PRINT "YOU CHOSE LEFT"
205 GOTO 60
210 PRINT "YOU CHOSE RIGHT"
215 GOTO 60
.. and ..
20 ON A GOTO 200,210
30 PRINT "YOU CHOSE NEITHER LEFT NOR RIGHT!"
40 GOTO 10
70 GOTO 10
205 GOTO 60
215 GOTO 60
Lee.
Personally I prefer INPUT with strings A$ and then apply some VAL() or possibly ASC() function to get a numerical value from it. In that way you won't get ?REDO FROM START if the users inputs a non-numerical value.
10 input "1 or 2";a$
15 a=val(a$):f=1
20 on a gosub 200,210
25 on f gosub 100,110
30 goto 10
100 print"you chose neither left nor right!":return
110 print"well done!":return
200 print"you chose left":f=f+1:return
210 print"you chose right":f=f+1:return
In this example, variable F acts like a fail flag. Depending on how your actual program turns out, the amount of error handling may differ. Of course if you're making any program with a bit of action, the GET syntax Mike mentions is preferrable over INPUT.
Just curious. Why did you F=F+1 instead of just F=1 for on or off?
Overall, I think I would have done the whole task differently, but I don't want to further complicate things. The above examples answer the question.
Good question. The ON X GOTO/GOSUB will only branch on X>0, so F=0 would bypass both the error message and the greeting. Thus F=1 from the beginning would assume the user made a mistake, and setting it to 2 (in this case F=F+1) simply upgrades the branch from error to greeting.
But if F=1 from the beginning as a fail flag, you could just say F=0 to change the fail flag and it would reset to one in the next prompt. That would 8 bytes. 9 if you lose the semicolon in line 10. :-P
10 input "1 or 2"a$
15 a=val(a$):f=1
25 if f gosub 100
30 print"well done!":return
40 goto 10
200 print"you chose left":f=0:return
210 print"you chose right":f=0:return
Jeff-20 wrote:[...] 9 if you lose the semicolon in line 10. :P
10 input "1 or 2"a$
... which gives you a '?SYNTAX ERROR'. :P
Anyway, this supposedly simple user request dialogue can obviously be programmed in thousandth of ways. Pedro just didn't get it right at the beginning, how to react in case the user input isn't valid.
Then the program can be designed in two ways: Either ignore invalid input, or report to the user, that the input is invalid. If the possible choices are presented on screen, IMO it isn't necessary to notify the user in case not one of the allowed inputs was done - i.e., ignore.
And of course there are better, and nicer ways to present the user with two or more alternatives to choose from. Like highlighting a menu entry by printing it in inverse script, much like it is done in VICtoria Gold. f1/f7 select an entry, pressing RETURN confirms.
Pedro Lambrini
Jeff-20 wrote:But if F=1 from the beginning as a fail flag, you could just say F=0 to change the fail flag and it would reset to one in the next prompt. That would 8 bytes. 9 if you lose the semicolon in line 10. :-P
10 input "1 or 2"a$
15 a=val(a$):f=1
25 if f gosub 100
40 goto 10
Right, okay, I think I follow this but I'm kinda with Jeff. I don't understand why F starts as 1 rather than the 0 which would be my assumption.
PS: Thanks for all these exapmles, they're all aiding in my learning. :)
10 input "1 or 2"a$
Oh, right. Stupid me. I haven't used INPUT in a long time. I thought it could be handled like PRINT.
Incidentally, I had my first ever
?ILLEGAL DIRECT
ERROR
I had never even heard of that one before! Over two decades and I'm still discovering things about this machine!
Well, my case of thinking was that more advanced subroutines would be called upon successful or incorrect input. Perhaps whole moves will be performed, routines that may even get called from other parts of the main program. In that case, it would make more sense to break those routines into subs and make sure to ON .. GOSUB both in case of success or failure.
5 tr=10:hu=10
10 print"you are followed by a troll. you have the following options:"
11 print"(1) fight the troll"
12 print"(2) flee into the forest"
13 h1=0:h2=0:input "your choice";a$
15 a=val(a$):f=1
30 hu=hu-h2:if hu>0 and tr>0 then 10
35 if tr>0 then print"the troll still stands up"
37 if hu>0 then print"you defeated the troll"
40 if tr<=0 and hu<=0 then print"both of you died!"
50 end
100 print"the troll hits you!":h2=int(rnd(1)*5)+1:return
110 tr=tr-h1:if tr>0 and rnd(1)>0.7 then 100
115 return
200 print"you hit the troll in its face!":f=f+1:h1=int(rnd(1)*5)+1:return
210 print"you escape into the bushes!":f=f+1:h1=0:return
In this little .. uh, game .. you can fight the troll. If you do nothing, the troll is sure to hit you repeatedly. Even if you fight or flee, there is a 30% chance the troll will come after you and give you a smackdown.
On lines 200-210, action is taken depending on your move. The subroutines at lines 100 and 110 however deal with the effects after the action is taken. Surely line 100 could have been incorporated into the main program, but it would have been uglier to do the branch for troll hitting back or code would have needed to be repeated.
I didn't make my question clear. If F is a flag, why did you F=F+1, instead of F=1? It seems like F would only be 0 or 1.
Ok, perhaps bad choice of word. Forget "flag", call it selector instead. Of course I might write ON F+1 GOSUB .. but it is almost even more cryptic.
Oh, I see what you're doing. I'm a little slow.
