Some Vic's are much hotter than others!!!!
I just bought a VIC 20 recently. It is a different model than my others. This one has a huge black looking heat sync on the right side of the motherboard. I noticed that while this puppy is turned on, this heat sync gets rather hot. In addition it, all the other chips on the motherboard get noticibly hot also. Has anybody out there noticed this on this particular model?
Barney
Barney
- Vic 20 Devotee
I believe the difference between the CR (DIN) models and the 2 prong models, may be that the 2 prong has part of the power supply, in the VIC20 case. Thus the need for the heatsink inside the case. Because the 2 prong only supplies 9V but the VIC20 requires 9V & 5V.
The wiki article on this is not very clear.
Without these modifications, the color yellow turns grey on this computer:
I probably overdid it on the following computer, but I had resoldered the power regulator so many times that the metal began to go bad on the motherboard.
I suspect that some of these troubles comes from the fact that they have increased the power voltage here from 220v to 230-240v...
I also think that heat was something of a design fault in the 2-prong model and that this was the one of the reasons why they made the CR model...
A funny thing is that the things left in the vic-20 seems to get a lot hotter than the PSU
- Mayhem
- High Bidder
I have to admit mine has been fine since I got it from my brother's girlfriend years back. Although yeah, it does seem to get hotter than the C64...Boray wrote:I also think that heat was something of a design fault in the 2-prong model and that this was the one of the reasons why they made the CR model...
- Pedro Lambrini
I have 5 working Vics 2 of which are the older 9v versions. Although they do get hotter than the 3 CR versions I find them both to be more stable and have better composite video and audio output. All in all, I think they're the better machine.
I second this. I only buy two-prong VIC-20s now.Pedro Lambrini wrote:I have 5 working Vics 2 of which are the older 9v versions. Although they do get hotter than the 3 CR versions I find them both to be more stable and have better composite video and audio output. All in all, I think they're the better machine.
It also helps with the overheating if you remove the cardboard from inside the VIC.
