Mega-Cart Tools V1.0 released (with dumper + full source)
tlr
Post by tlr »
Mega-Tools is a collection of a NvRAM writing utility, a ROM dumper, some examples and some technical information.
Download: mega-tools-1.0.tar.gz
(full source code included)
rhurst
Omega Star Commander
Occupation: Tech & Innovation
Post by rhurst »
8)
Diddl
Post by Diddl »
Thanks for this utility!
And think about, every MegaCart has a own serial number. And the owner is known ... :)
nbla000
Salmon Run
Post by nbla000 »
Many thanks for your tools tlr, I hope Mega-Cart users will enjoy it with VICE !!!
Diddl wrote:And think about, every MegaCart has a own serial number. And the owner is known ... :)
Yes right so be careful, please use grubbed files for your personal use :wink:
I hope to find time for a vice image's "light version" of the Mega-Cart firmware so I will publish it on www.mega-cart.com
Thanks again tlr for your tool and for VICE Emulation of course, it's really an honour for me to have Mega-Cart emulated on VICE.
I hope you find time to emulate also sd2iec based drives on VICE, it will be very useful for software developing and for users general testings before/after buying ones.
Diddl
Post by Diddl »
nbla000 wrote:I hope you find time to emulate also sd2iec based drives on VICE, it will be very useful for software developing and for users general testings before/after buying ones.
Yes, I agree!
+ No real emulation is nessecary.
+ A given path (directory) and below (subdirectories)
+ SD2IEC/CMD commands to change directory
+ SD2IEC/CMD commands to enter/leave imagefile
+ Block read/write within a Imagefile
+ Jiffy compatibility
+ SD2IEC commands for realtime clock
Pedro Lambrini
Post by Pedro Lambrini »
So, how would I use this to rip a ROM image of my Mega Cart? I don't have ready access to my Vic at the moment but it would be nice to have clear instructions for when I do. :)
nbla000
Salmon Run
Post by nbla000 »
tlr may help you but I think you need a uIEC/SD2IEC or a drive that may store at least 1MB, better 2MB.
You need also a lot of time :wink:
Diddl
Post by Diddl »
The GUI of the dumper is very easy to understand.
You need at least any drive cause you can split dump into many parts. A 1581 drive takes 4 disks for a full dump.
Best use is a SD2IEC (or µIEC) so you can dump it simple (without many disk changes).
Pedro Lambrini
Luckily I have a uIEC so that should make life a little easier. I'm not at home much of the time just now as I move around a lot because of work but I hope to get to my lovely Vic within the next week or so. It'll be great to have the Mega-Cart with the new ViCE and GB20 on my Dell Mini 9! Now, if only I could get all that on my iPhone!
I wonder if the dumper could be merged with any of the cbmlink servers (less than 512 bytes each) which would allow you to use a C2N232, null modem or some kind of parallel (PC64, prlink, X1541 etc) cable. If that was possible, one could dump the Mega-Cart directly to a PC through a cable. It still would be slow though, and lock up your PC for as long time as your VIC is running.
Jake64
Post by Jake64 »
I yesterday did the dump with c64+1541u+vic+mecacart and program mega-extract.prg. And then used it with Vice 2.2.
Super ! :D
Post by Vic20-Ian »
Just adding a quicl post to make this thread more searchable - took me 20 mins to find it.
megacart dumper mega cart dumper extract rom
Post by Vic20-Ian »
dumped in about 30 minutes or so using the Brain uIEC SD.
Schlowski
NoMess!
Post by Schlowski »
Did it really take so much time? I made the same yesterday (and yes, I had to search a long time to dig out this thread, too) and think it was faster, like 10 minutes or so.
Post by Vic20-Ian »
yes it took a while at least 20 minutes probably 30 but all is working in Vice 2.2 now. Ready for 3.5 weeks on the road away from the Vic :-(
