Anyone know what this cart is?
Hi everyone,
Recently I picked up this interesting looking cartridge, mainly as it had the Mr Micro logo on it. Originally from the ebay auction picture, it looked like it might be a C64 based cart - but upon arrival I found it was a Vic 20 cart (Or at least has the same amount of pins).
I tried plugging it in, but nothing happens (Even with another cartridge plugged into the expansion part at the back). I guess it might need a SYS call to get it going.
But any ideas what it might be?... I wondered if it was some kind of cartridge backup system due to the expansion part. Never seen any adverts in the old magazines from Mr Chip, apart from their games.
- Pedro Lambrini
The four contacts in the middle would address BLK 1..3, and BLK 5.
But they aren't connected, but the ones left two them - addressing RAM 1..3 - are, and these lines go to two TTL's.
I'd assume, that this adapter cart maps the some of BLK address range of ordinary carts into the $0400 .. $0FFF range. You could try whether an 8K RAM expander shows up as 3K RAM expander, with that adapter in-between.
It should be. Afaik all 8k carts look the same to the VIC 20.fgasking wrote:Thanks Mike - i'll give that a try when I next get chance. Will a Vixen multi-ram cart set to 8k be sufficient for a test?
Bacon
Right, I used a Vixen cart set to 8k .. giving 12xxx bytes free etc and plugged that in. This time I got something different - just a black/blank screen when switched on. So it seems to have triggered something.
Pressed some keys, joystick buttons etc - but nothing though.
As requested, here is the back with the tape removed. Hopefully this might help shed some light. Glad I picked this up in the end (Only because of Mr Micro logo did it pique my interest).
I reverse engineered it. It appears to map an 8K RAM cart at BLK1 into RAM-RAM3. But, since BLK1 is only 8kB, it maps RAM2 and RAM3 into the same 4kB bank, as far as I can see.
Strangely, the dual TTL ICs seema waste. They are 70LS00 units, as far as I can tell from the reverse engineering. But, the outputs are all negated with second 74LS00 units wired as inverters. A single '08 would have done the same job.
Schematic at: http://www.jbrain.com/vicug/gallery/misc/Mr_Micro
Jim
Jim
Hi Jim,brain wrote:I reverse engineered it. It appears to map an 8K RAM cart at BLK1 into RAM-RAM3. But, since BLK1 is only 8kB, it maps RAM2 and RAM3 into the same 4kB bank, as far as I can see.
Jim
Could you tell us what software you use to generate your schematics?
Thank you
EAGLE: www.cadsoftusa.comGabriel Angelos wrote: Hi Jim,
Thank you
If I am doing rev-engr, I also use PhotoImpact to mirror the back PCB and lay it over the top at 50% transparency, which makes it easier to rev-engr.
Jim
Thanks Jim!brain wrote:EAGLE: www.cadsoftusa.com
Jim
Found what it is!! .... Searching through the Home Computer Weekly scans when I found this:
The "Ramdam"
http://gtw64.retro-net.de/vicscans/ramdam.jpg
Seems to match what people have found.
The advert mentions a memory test program and a "MicroVaders" game that comes with it. I suspect its a tape (Which sadly I don't have), but wonder alternatively by chance if the game "MicroVaders" could be hidden away on the cartridge and accessible via a SYS call? (Any that I can try?)
The "Ramdam"
There is no game hidden away on the cartridge.
The cartridge you have physically remaps a 16K ram pack to act as if it is a 3K expansion.
This allows you to play something like Skyhawk 3K version on a Vic20 with 8k or 16K expansion without having to buy a separate 3K cartridge.
The games mentioned would have come on tape or maybe a listing as an enticement to buy it. There is nowhere to store them on those logic chips on the cartridge.
I checked GameBase V2 and the game by Mr Micro called Microvaders and Memory test utility are not listed....yet.
